Lower Jpeg Quality
tokrot
Lower Jpeg Quality
Unread postby tokrot » 06.04.2004 14:19
Hi, I decided to give this program a try and the result I would say is stunning. However, I discovered that the Jpeg pic saved tend to be different from the preview. It looks like a slight lower Quality jpeg. Does anyone notice that? Thanks..
~Mike
Unread postby Dan Kozub » 06.04.2004 14:23
yes, we know about this problem and in the next version the quality will be higher
Guest
Unread postby Guest » 06.04.2004 17:43
Dan Kozub wrote:yes, we know about this problem and in the next version the quality will be higher
Thanks glad that you guys know this problem.. :D
tokrot
Unread postby tokrot » 21.04.2004 07:42
I just tried out the new version. The Jpeg quality still not fixed and other problem is that the output file seems to create twice as big file as original when set to 10 Jpeg quality.
Unread postby Dan Kozub » 21.04.2004 08:04
We calibarate our output with Photoshop. Try to resave your original file from Photoshop with quality of 10 and you'll get the same file size as from Helicon NoiseFilter.
Unread postby Dan Kozub » 21.04.2004 08:56
tokrot wrote:Hi,
Have you set jpeg quality in Preferences?
tokrot
Unread postby tokrot » 21.04.2004 17:55
I have set the jpeg to 12/12 (100/100) quality and do a 20 and absolute value..
Look at the highlight output square box, there's a red dot in it.
after saving the file, the file size increased from 372k to 414k and the red dot seems to be disappeared as show different from the output preview..
Hope you got what I mean....
Unread postby Dan Kozub » 21.04.2004 18:22
Hm.. I understand what you mean.
Try to save it as BMP and compare with JPEG.
