Nikon 7200 problem
MikeCT
Nikon 7200 problem
Post by MikeCT »
After upgrading from a Nikon D5300 to a 7200 I cannot get the focussing arrows to work. If I switch back to the 5300, all is fine. The camera settings are the same on both.
Any suggestions?
Re: Nikon 7200 problem
Please reproduce the problem and submit a bug report (menu -> Help -> Report a bug). By the way, did you test 5300 and 7200 it with the same lens or different ones? Did you make sure all the focus mode settings and hardware swicthes are set to AF (or AF-S if there's more than one AF option)?
MikeCT
Post by MikeCT »
Stas Yatsenko wrote:Please reproduce the problem and submit a bug report (menu -> Help -> Report a bug). By the way, did you test 5300 and 7200 it with the same lens or different ones? Did you make sure all the focus mode settings and hardware swicthes are set to AF (or AF-S if there's more than one AF option)?
Okay Stas: I feel really dumb. The hardware switch was on Manual. The reason I hadn't noticed is that there was a small piece of tape that had somehow covered the white position marker and I simply misread the setting.
Many thanks for you patience
