Where do I get a cable?
My Samsung Android phone has a non-standard USB connector, as does my Nikon D600. I need a special cable, obviously, but where do I find it? Thanks!
Re: Where do I get a cable?
The Nikon D600 & most Samsung use standard micro-B USB cable connections.
The Samsung cable MUST be an otg cable to host the D600 and it has a socket for the standard USB -A plug, which is on the other end of the D600 cable. All these cables are very cheap on ebay. Look for "Micro USB to USB Adapter OTG Cable Samsung" & "USB to Micro B Cable" for the Nikon.
My phone is a Samsung Galaxy S5. It does not have a micro USB connector, but only the connector shown in the attached photo (which shows both the male and female connectors). I use this to link with my computer. Can I use it to connect with my camera? Thanks.
- (180.39 KiB) Downloaded 97 times
- mike_mccue
The Samsung uses a "micro USB 3.0" connector. It seems like the Nikon uses a "mini USB 2.0" connector.
It's easy to find cables with a micro USB 3.0 connector, but I couldn't find the exact cable you need for your Camera and phone combo. You may need to use some sort of adapter to go from a common micro USB 3.0 to USB A male cable
and then adapt from the USB A male to get to the mini USB on the Nikon.
Start by confirming the USB connector size on the Nikon.
Good luck!
Good luck!
Sorry yes the Nikon is 5 pin Mini-B USB 2.0, your Samsung is Micro-B, USB 3.0
search Ebay for "Mini USB 2.0 to USB 2.0A cable" and "MICRO USB 3.0 to Female USB OTG"
Thanks all for very useful replies. My adapter is "in the mail."
The pictures look right. The main cable is the one that's bundled with the camera (you definitely have it if you've bought the camera new). It's the same cable you'd use for connecting the camera to a computer. And the second thing you need is a USB OTG adapter. Note that it's not just any USB A socket to micro USB plug adapter. It MUST be labeled as OTG or it won't work.
Looks like we should expand the FAQ entry with pictures...
http://www.heliconsoft.com/faq-helicon-remote/#cables
