Which tablets are confirmed working?
erpman
Post by erpman » 30.10.2013 12:37
Hi
I´m going to purchase a tablet and helicon remote to use in the field. There seems to be a lot of compatibility issues when using tablets. Can someone provide a list of the exact tablets/operating systems currently on the market (and not too expensive) that are confirmed working with Nikon d800?
Thanks!
Re: Which tablets are confirmed working?
Post by Stas Yatsenko » 30.10.2013 13:13
No one can provide such a list, otherwise it would be on our site. The only way to make 100% sure it will work is to test in the shop. If that is impossible, we can name a few devices that have the neccessary hardware, but you might need to install custom Android firmware (ROM) to make it work.
Guest
Post by Guest » 30.10.2013 22:38
What about Lenovo A1000?
Post by Stas Yatsenko » 31.10.2013 14:22
Never heard of it, so can't say. Like I said, there's no easy way to determine because even if the tablet has the neccessary hardware, it may come with different Android versions. That's unlikely, but possible.
Guest
Post by Guest » 01.11.2013 15:47
Now I just tested it and its working without problems.
Lenovo MeMoPad A1000: a $130,- tablet that runs helicon remote :D
Elrique64
Post by Elrique64 » 20.01.2014 02:39
I can confirm Remote working on a Toshiba Thrive 10" and an Asus TF700T both wired and wireless with the WU-1a to a Nikon D7000 (wired) and a D7100 (wired and wireless).
although the wireless operation with the WU-1a and the D7100 have some issues finding the camera first time around. (Still having issues with this, jst have to keep trying..)
Mike G.
Post by Stas Yatsenko » 20.01.2014 16:57
If you figure out what causes issues or how to avoid them - please tell.
EricF
Post by EricF » 21.02.2014 01:25
I have a Nexus 7 (2013) tablet running Android 4.4.2. I downloaded both the Win7 and Android Helicon Remote trial version apps. The Win7 version detects the camera and operates flawlessly. However, the Android app runs, but doesn't detect the camera (a Nikon D5100).
In an earlier post, Stas Yatsenko said "you might need to install custom Android firmware". Is there more info about this?
Or, has anyone else been able to get this running on a Nexus 7?
Post by Stas Yatsenko » 21.02.2014 12:26
There's a known issue with Nexus 7. Refer here for workaround: http://nexususb.blogspot.co.uk/2013/07/android-4.html
Also, make sure you're using a USB OTG adapter and not just any cable / adapter. OTG adapter is a micro USB plug to USB A (full size) socket adapter with a special pin layout.
