Remote software not working
ladamache
Post by ladamache »
I've had Helicon Focus Pro installed on my workstation (Vista Pro 64 bit) and it seems to work fine. I wanted to try out Helicon Remote to do some flower macros, so I downloaded & installed it on my laptop (Vista business 32 bit). I connected my Canon 1DS III to my laptop & it works fine with the EOS utility. When I start up Helicon Remote, the large window shows camera not connected, but small window in top right shows it connected. At this point, the software and the camera seem to freeze - I can't operate either. I tried this several times & re-installed the software with same result. Is it possible that 64 bit software has been installed on my 32 bit laptop? I need to shut down Remote with the Task Manager. There have been some application error access violation messages as a result.
What have I been doing wrong? Any suggestions?
Re: Remote software not working
I suspect that small window is some other application (Canon Utility?) and this application uses connection with the camera. I suggest to close this application and then start Helicon Remote. This should help. If not, a printscreen of your desktop would help us to understand the problem.
ladamache
Post by ladamache »
Hi Stas
Thanks for replying.
I used the wrong terminology in my post. The place where my camera shows up is in the top of the "camera settings" box (not window) in the top right-hand corner of Helicon Remote screen. No other applications are running. The top LCD on my camera has a "busy" signal.
No point in showing a printscreen as there is nothing else showing on the Helicon Remote Screen except the "spinning circle" showing it is busy (hung).
Larry
Larry,
We will send you a link to newer dll via private message in the forum. It created more detailed log. Please replace this dll and send us the log.
ladamache
Post by ladamache »
Hi Stas
Where do I find this private message with the newer dll? Am I missing something here?
Cheers
Larry
Larry,
Please download http://www.heliconsoft.com/downloads/HeliconRemote.zip and unpack it into Helicon Focus folder.
ladamache
Post by ladamache »
Hi Stas
I installed the changes to Helicon Remote that you made available. Unfortunately, nothing seems to have changed. When I open Helicon Remote, I have access to the software, but when I turn the camera on there is a noise that sounds like the mirror is locking up then Helicon Remote hangs. Task Manager shows "Helicon Remote not responding". If I turn off the camera there is another click that sounds like the mirror is going down.
If I restart Helicon Remote, clicking on the session logs results in an error message: Access Violation at address 754521DC (or other address) in Secur32.dll. Read of address 0000000C.
I opened these logs with a text editor. The references to Nikon seem strange.
I hope this is of some help.
Regards
Larry
Log of Current Session
03157.303 Version of library remoteControl: 1.1.1(10.05.2010) 0x0000007b
00000.175 OS Microsoft Windows Vista Business Edition, 32-bit Service Pack 2 (build6002)
00000.066 Start 13.05.2010 21:39:04
00000.058 CSdkBase: creating
00000.049 CSdkBase: create all SDK, begin
00000.056 CCanonSdk: creating session
00009.345 CCanonSdk: created
00000.097 CNikonSdk: creating
00000.052 CNikonSdk: findModule, begin
00000.051 CNikonSdk: findModule, end, (D200_Mod.md3)
00000.146 CNikonSdk: loadModule, begin
00002.329 CNikonSdk: findModule, end
00000.079 CNikonSdk: openModule, begin
00073.134 CNikonSdk: openModule, end
00000.058 CNikonSdk: created
00000.045 CNikonSdk: creating
00000.036 CNikonSdk: findModule, begin
00000.042 CNikonSdk: findModule, end, (Type0001.md3)
00000.033 CNikonSdk: loadModule, begin
00003.132 CNikonSdk: findModule, end
00000.056 CNikonSdk: openModule, begin
00054.578 CNikonSdk: openModule, end
00000.061 CNikonSdk: created
00000.043 CNikonSdk: creating
00000.042 CNikonSdk: findModule, begin
00000.033 CNikonSdk: findModule, end, (Type0002.md3)
00000.030 CNikonSdk: loadModule, begin
00002.567 CNikonSdk: findModule, end
00000.052 CNikonSdk: openModule, begin
00097.689 CNikonSdk: openModule, end
00000.059 CNikonSdk: created
00000.040 CNikonSdk: creating
00000.029 CNikonSdk: findModule, begin
00000.035 CNikonSdk: findModule, end, (D40_Mod.md3)
00000.028 CNikonSdk: loadModule, begin
00001.962 CNikonSdk: findModule, end
00000.047 CNikonSdk: openModule, begin
00048.759 CNikonSdk: openModule, end
00000.072 CNikonSdk: creating
00000.030 CNikonSdk: findModule, begin
00000.031 CNikonSdk: findModule, end, (D80_Mod.md3)
00000.027 CNikonSdk: loadModule, begin
00002.062 CNikonSdk: findModule, end
00000.044 CNikonSdk: openModule, begin
00060.361 CNikonSdk: openModule, end
00000.055 CNikonSdk: created
00000.038 CNikonSdk: creating
00000.031 CNikonSdk: findModule, end, (Type0003.md3)
00002.617 CNikonSdk: findModule, end
00062.588 CNikonSdk: openModule, end
00000.053 CNikonSdk: created
00000.035 CSdkBase: create all SDK, end
00000.029 CSdkBase: created
Logof Previous Session
05055.219 Version of library remoteControl: 1.1.1(10.05.2010) 0x0000007b
00000.224 OS Microsoft Windows Vista Business Edition, 32-bit Service Pack 2 (build6002)
00000.064 Start 13.05.2010 16:22:03
00000.059 CSdkBase: creating
00000.048 CSdkBase: create all SDK, begin
00000.110 CCanonSdk: creating session
00261.926 CCanonSdk: created
00000.104 CNikonSdk: creating
00000.052 CNikonSdk: findModule, end, (D200_Mod.md3)
00000.111 CNikonSdk: loadModule, begin
00156.360 CNikonSdk: findModule, end
00000.085 CNikonSdk: openModule, begin
00202.784 CNikonSdk: openModule, end
00000.068 CNikonSdk: created
00000.050 CNikonSdk: creating
00000.043 CNikonSdk: findModule, begin
00000.046 CNikonSdk: findModule, end, (Type0001.md3)
00000.039 CNikonSdk: loadModule, begin
00218.888 CNikonSdk: findModule, end
00000.083 CNikonSdk: openModule, begin
00090.234 CNikonSdk: openModule, end
00000.075 CNikonSdk: created
00000.060 CNikonSdk: creating
00000.058 CNikonSdk: findModule, begin
00000.047 CNikonSdk: findModule, end, (Type0002.md3)
00000.043 CNikonSdk: loadModule, begin
00577.862 CNikonSdk: findModule, end
00000.092 CNikonSdk: openModule, begin
00112.412 CNikonSdk: openModule, end
00000.094 CNikonSdk: created
00000.075 CNikonSdk: creating
00000.057 CNikonSdk: findModule, begin
00000.066 CNikonSdk: findModule, end, (D40_Mod.md3)
00000.054 CNikonSdk: loadModule, begin
00560.349 CNikonSdk: findModule, end
00000.096 CNikonSdk: openModule, begin
00112.785 CNikonSdk: openModule, end
00000.061 CNikonSdk: findModule, end, (D80_Mod.md3)
00000.053 CNikonSdk: loadModule, begin
00716.119 CNikonSdk: findModule, end
00000.067 CNikonSdk: openModule, begin
00071.097 CNikonSdk: openModule, end
00000.065 CNikonSdk: created
00000.044 CNikonSdk: creating
00000.035 CNikonSdk: findModule, begin
00000.038 CNikonSdk: findModule, end, (Type0003.md3)
00330.961 CNikonSdk: findModule, end
00000.071 CNikonSdk: openModule, begin
00136.797 CNikonSdk: openModule, end
00000.091 CNikonSdk: created
00000.067 CSdkBase: create all SDK, end
00000.058 CSdkBase: created
517883.750 CSdkBase: destroying
00000.063 CSdkBase: stopSession, begin
00000.000 CSdkBase: stopSession FAILED: session was not started
00000.063 CSdkBase: remove all cameras, begin
00000.000 CSdkBase: remove all cameras, end
00000.063 CSdkBase: destroy all SDK, begin
00000.000 CCanonSdk: destroying
00001.250 CCanonSdk: destroyed
00000.688 CNikonSdk: destroying
00002.188 CNikonSdk: unloadModule, begin
00000.250 CNikonSdk: unloadModule, end
00000.000 CNikonSdk: destroyed
00000.063 CNikonSdk: destroying
00001.250 CNikonSdk: unloadModule, begin
00000.188 CNikonSdk: unloadModule, end
00000.063 CNikonSdk: destroyed
00000.000 CNikonSdk: destroying
00001.188 CNikonSdk: unloadModule, begin
00000.125 CNikonSdk: unloadModule, end
00001.500 CNikonSdk: unloadModule, begin
00000.063 CSdkBase: destroy all SDK, end
00000.000 CSdkBase: destroyed
Larry,
Thanks for the log. No news so far. We can't reproduce the bug and can't understand why it can happen. We are now working on internally new version and hopefully the bug will be fixed. Please wait a couple of weeks.
ladamache
Post by ladamache »
Thanks Stas. Will wait.
Cheers
Larry
russ heller
Post by russ heller »
i have noticed that certain errors will cause the remote program to hang up. try formatting your memory card in the camera and restarting the computer/ software. shooting with mirror lock-up and using the shot preview buttons seemed to make the hang-ups more likely.
ladamache
Post by ladamache »
Hi Russ
Thanks for your suggestions. I always reformat the memory card in my camera and I've already tried your other suggestions as well as other possibilities. I've tried this on both my laptop and my desktop Windows Vista systems with the exact same results. Helicon Remote (including the latest version) hangs as soon as the camera is turned on and Windows Task Manager reports that Helicon Remote is not responding. The Canon remote utility seems to work OK however.
On the chance that it might be a problem with my camera (1 DS3) I just sent it in to Canon Service Centre for checking.
Larry,
We found and fixed the bug with MLU mode. We will send you a link by mail. You are welcome to try it this help in your case.
ladamache
Post by ladamache »
Thanks Stas
My camera won't be back from Canon for a couple of weeks. Will try your new changes then.
Cheers
Larry
ladamache
Post by ladamache »
Hi Stas
I finally got my camera back from Canon. They checked the remote function and could not find anything wrong with the camera. Today, I tried again to connect with Helicon Remote 1.19 Beta and I get the same response as before. I open Helicon Remote and I can navigate around the "preferences" and "help" on the program. I then turn my camera on and it shows up in the "camera settings" box then Helicon Remote freezes. Windows Task Manager show the program is not responding.
I've now downloaded and installed several versions of Helicon Remote and the same thing happens.
Are there any settings on my camera that could be causing this behavior?
Regards
Larry
Larry,
We will send you the new version of Helicon Remote on email, please test it and let us know.
