Non Focus stepping partially solved
BrianS
Post by BrianS » 29.10.2009 15:18
Stas,
partially good news.
I discovered that if you have mirror lock up enabled, then HR in Auto mode:
- does not perform the focus steps
- writes the first image to the PC - the rest to the card on the camera
OK so easily fixed by turning off Mirror lockup - however in Manual shot mode, the focus steps are still not performed.
I assuming that once I have set the nearest-farthest points, returned to nearest, then click new stack, then on each click of Take Picture , HR should move a focus step?
If so, it isn't working - or am I supposed to manually perform the focus step as well?
Brian
Post by Stas Yatsenko » 03.11.2009 15:15
Brian,
We will send a new version of HR to your e-mail
BrianS
Thanks Stas
Post by BrianS » 03.11.2009 15:46
Stas,
I'll check it out ASAP after it arrives.
