Dark fringe/halo
Locked
johndavidson
Dark fringe/halo
Post by johndavidson » 24.02.2019 02:07
Just starting out using this software, and I must say I'm quite impressed. However, I'm having a problem which I suspect is me rather than the software.
Took a series using Helicon Remote. Subsequent processing produces images with some dark fringing around the edges. What's going on here?
(979.6 KiB) Not downloaded yet
I used default processing, changing no settings.
Re: Dark fringe/halo
Post by Stas Yatsenko » 25.02.2019 12:21
Most likely, something in the way the source images are shot or aligned is triggerring this. We need to see the whole stack of source images to figure out what's going on, can you share them?
johndavidson
Post by johndavidson » 25.02.2019 14:48
Sure. I’ll load them onto OneDrive and post the link if that’s OK.
I’ve also noticed that the effect is reduced if I increase the radius setting.
johndavidson
Post by johndavidson » 25.02.2019 21:44
Link to onedrive folder. There are 12 images.
https://1drv.ms/f/s!Apj2TZRQngcCuTE9_4sWr2-l6A79
Post by Stas Yatsenko » 26.02.2019 11:23
This is optical effect and stacking is not able to change this. We can only suggest to set smaller aperture to minimize this effect.
johndavidson
Post by johndavidson » 26.02.2019 11:47
Ok. I’ll try it out over the next few days. Thanks for looking.
Locked
