Main Menu Not Accesible in iOS 12.0.1 on iPhone
pjsmd
Post by pjsmd » 21.10.2018 15:45
I am now a Premier registered user and enjoy the program immensely. I shoot RAW and was successful in getting the Remote app running as a registered user on my iPad (which happens to have iOS 10.3.3 still) but not my iPhone XS (which has the most recent iOS 12.0.1). I think there is a bug in your software. On my iPhone XS (iOS 12.0.1), the little menu icon on upper right (the one with the horizontal lines with a dot on left of top, right of second and middle of third) is inactive. Tapping it does nothing. This is not an issue with my iPad. I think what is happening is that little piece of screen real estate is reserved in the new iOS 12.0.1 for drag down (to quick access light, WIFI, Bluetooth, etc). In fact if one drags down on your menu item, you get to the iOS control center. If that could be confirmed, perhaps you could fix this by moving the menu out of the reserved area on your next bug fix. Since I have the older iOS on my iPad, I can't be sure it is the iOS - could also be device specific somehow.
Re: Main Menu Not Accesible in iOS 12.0.1 on iPhone
Post by Stas Yatsenko » 22.10.2018 12:41
Thanks for the detailed description of the problem. We're already aware of it and will fix the problem in the upcoming update. Try tapping the empty area to the right of the menu button, there's a chance that will display the menu.
cpburki
Post by cpburki » 16.03.2019 07:04
I am experiencing the exact same problem. When will the fix be issued?
cpburki
Post by cpburki » 16.03.2019 07:19
I am having the very same issue with my iPhone XS Max ruling on IOS 12.1.4. I have the HelisonRemote running on my new iPad Pro 11" that is also running on IOS 12.1.4 and it runs just fine and able to select the Help Menu in order to Sign In. When will HeliconSoft issue a fix for this?
Post by Stas Yatsenko » 18.03.2019 11:52
We're working on it, need to sort out a few other things, I don't know exactly when we'll be able to release the update. Tap on the empty space to the left of the menu button to invoke the menu.
