GPS coordinates
Arend041
GPS coordinates
Unread postby Arend041 » 30.05.2015 17:12
Coordinates generated with the HeliconPhotoSafe program, the place is the Sagrada Família in Barcelona.
Opened the picture in IrfanView and inspected the EXIF stuff and pressed to view in Google Maps and I was dropped in the sea.
I resetted the Coordinates in Picasa (Sagrada in Barcelona)
opened in IrfanView as before and I came perfectly in the Sagadra
The coordinates generated with the Helicon program are not correct and they are not recognized in Picasa and did give the wrong place on the map.
Here a link how to display the coordinates:
http://www.gps-coordinates.net/
see the header:
Google Maps Driving Directions
DD (decimal degrees)
DMS (degrees, minutes, secondes)
Re: GPS coordinates
Unread postby Stas Yatsenko » 03.06.2015 11:08
Thanks for this report. We will check it ASAP. Helicon Photo Safe uses coordinates as reported by Google Maps API.
Arend041
Re: GPS coordinates
Unread postby Arend041 » 01.07.2015 11:23
LS,
in the meantime I've found software that do the job correctly
thanks for your time
