Large-ish project keeps crashing
DimitriKatsaros
Post by DimitriKatsaros » 08.12.2016 03:18
A 78-image project that I am doing a _ton_ of retouching on repeated crashes as I am retouching an flipping between the layers using the page up and page down keys as I brush in detail. Additionally, the saved project file takes quite a bit of time to load.
I tried sending a bug report, but I didn't get a response so I'm not sure if it went through.
Any hints to stop all this lost time (I'm forced to save every 20 or 30 minutes to minimize loss) would be appreciated in the extreme. :-)
Thank you
Dimitri Katsaros
Re: Large-ish project keeps crashing
Post by Stas Yatsenko » 08.12.2016 16:26
Looks like we didn't get your report. Is it happening on Windows or Mac?
How long does the project file take to load, exactly? And what CPU model does the system have?
DimitriKatsaros
Post by DimitriKatsaros » 09.12.2016 21:21
It's happening on my Mac Pro (late 2013) with 3.5 GHz 6-Core Intel Xeon E5, 64 GB 1866 MHz DDR3, and a pair of AMD FirePro D500 3072 MB
The OS is 10.12.1 (16B2555) -- Sierra
Version of Helicon Focus is 6.7.1 Pro
I'll find out later today how much time it takes to reload if it will help.
Oh, and as it reloads, the dialog box where you choose the project file stays as a white box for some time until the project shows up... then, to see the retouching I have to switch from the Rendering tab to the Retouching tab... then, after switching tabs, it takes even more time for the retouches to show up completely.
Dimitri Katsaros
DimitriKatsaros
Post by DimitriKatsaros » 12.12.2016 21:39
Project crashed again today, so I reopened the program and then the project....
time to open the project: 8 minutes 46 seconds
time for the retouching edits to load: 11 minutes 20 seconds
for a total of: 20 minutes 6 seconds
For completeness (not sure if this will help) here is the data that was sent in the bug report:
int main(int, char **): Branding file path: "/Applications/HeliconFocus.app/Contents/MacOS/../Resources/branding"
int main(int, char **): "Helicon Focus 6.7.1 x64"
int main(int, char **): Running on "OS X 10.12 (16.1.0) x86_64"
int main(int, char **): 12 physical CPU cores, 12 logical CPU cores
int main(int, char **): Built on May 27 2016 at 13:43:09
int main(int, char **): keys.ini file path: "/Library/Application Support/Helicon/keys.ini"
int main(int, char **): Pro license
int main(int, char **): License days left: 119
: Unknown property size
void ImagesCache::saveImageAndCache(HLImage *, const QString &, const ImageSaveOptions &, ProgressObserver *): cache size before save 0
void Graphics::invalidateRect(HLRect): invalidateRect 0 0 0 0
void MainWindow::setCurrentTask(Task *): Viewing images: 0x0 0x7fdc15de70e0 0x0 0x7fdc15f69ec0 0x7fdc15c6d970
void MainWindow::onReportBug(): invoked upon the user request
AKDeviceUnlockState=true
AKLastCheckInAttemptDate=2016-12-11T08:42:03
AKLastCheckInSuccessDate=2016-12-11T08:42:03
AdjustBrightness=true
AdjustHorizontally=3
AdjustRotate=0
AdjustScale=5
AdjustVertically=3
AdobeDNGConverterFilePath=/Applications/Adobe DNG Converter.app/Contents/MacOS/Adobe DNG Converter
Apple Inc/ Apple Mobile Device (DFU Mode)=1
Apple Inc/ Apple Mobile Device (Recovery Mode)=1
Apple Inc/ iPad=1
Apple Inc/ iPhone=1
AppleActionOnDoubleClick=Minimize
AppleAntiAliasingThreshold=4
AppleAquaColorVariant=1
AppleKeyboardUIMode=1
AppleLanguages=en-US
AppleLanguagesDidMigrate=10.12.1
AppleLocale=en_US
AppleMiniaturizeOnDoubleClick=true
AppleShowAllExtensions=true
AppleShowScrollBars=Always
AppleTextDirection=0
AutoadjustmentsInterpolation=30
BugReportUserEmail=dcka@yahoo.com
CheckForUpdates=true
Country=US
DepthMapFeathering=3
Generic Mass Storage=1
Griffin Technology, Inc/ iMate, USB To ADB Adaptor=1
IgnoreExif=false
Keys/0=5534727351555674704155656f43647677784c476868554a7355364a504a554f527241514c612b4564504f3d
Keys/1=6149414d456a6e41624d6a414c32664d5476575731576530536e7a7a54382f4c69796a76667164595a70683d
Keys/2=42314475756779577452544d4c68766d533874686647314a43796a36306e3466695242375877666732306e3d
Keys/3=4c6d637667567a5047626f4c6832367446745647424e6776684b737746614f7a6b307364477178686630643d
Keys/4=54645752415269494130484a737859464754497067785a763371446f614f4d485239456e5276316832594e3d
Language=english.lng
LastBrushSize11=8
LastBrushSize12=18
LastFocusMethod=14
LastFocusRadius=8
LastFocusSmoothing=1
LastProjectDir=/Volumes/LaCie/ReStack/Final Stack
LastSaveResultDir=/Volumes/LaCie/ReStack/Final Stack
LastSaveResultFilter=1
LastUpdateCheck=1481569993
Lexar WorkflowSR1=1
LightroomPluginInstalled=true
MagnifierSize=1
MainWindowGeometry=01d9d0cb0002000000000006000000170000072c0000063a000000060000002d0000072c0000063a00000000000000000a00
MainWindowSplitOrientation=1
MainWindowState=000000ff00000000fd0000000000000727000005bb00000004000000040000000800000008fc0000000100000002000000010000000e0074006f006f006c0042006100720100000000ffffffff0000000000000000
Microsoft IOUSBHostDevice=1
MonitorProfile=
MouseDragAcceleration=5
MultipleSessionEnabled=true
NEC PA302W=1
NSAutomaticDashSubstitutionEnabled=true
NSAutomaticQuoteSubstitutionEnabled=true
NSAutomaticSpellingCorrectionEnabled=true
NSCloseAlwaysConfirmsChanges=true
NSLinguisticDataAssetsRequestTime=2016-12-11T20:47:33
NSLinguisticDataAssetsRequested=
NSNavPanelFileLastListModeForOpenModeKey=2
NSNavPanelFileLastListModeForSaveModeKey=2
NSNavPanelFileListModeForOpenMode2=2
NSNavPanelFileListModeForSaveMode2=2
NSNavPanelSidebarKeyForOpen=
NSNavPanelSidebarKeyForSave=
NSNavPreviewExpanded=true
NSNavRecentPlaces=
NSNavSortOrder=
NSNavSortOrder_10/6=
NSPersonNameDefaultDisplayNameOrder=0
NSPersonNameDefaultShortNameFormat=0
NSPersonNameDefaultShouldPreferNicknamesPreference=0
NSPreferredWebServices=
NSTableViewDefaultSizeMode=2
NSUserDictionaryReplacementItems=
NavPanelFileListModeForOpenMode=2
NavPanelFileListModeForSaveMode=2
NavPanelSpotlightSearchScopeMode=0
OWC Mercury Optical=1
Other World Computing OWC Express USB 3/0=1
OutputDpi=360
PanoramaAdjustHorizontally=1
PanoramaAdjustVertically=1
PlaySounds=true
RawSettingsDialogGeometry=01d9d0cb00020000000001000000008a000008ff000004ff00000100000000a0000008ff000004ff00000000000000000a00
SaveFilenameTemplate=[DATE] [TIME] ([PARAMS])
Schiit USB Audio Device=1
ShowIntermediateResult=true
ShowWelcomeScreen=false
SourceFilesAutoSort=true
SourceFilesListViewThumbnailSize=2
SourceFilesSortOrder=1
SyncServicesServerWasActive=true
TempDir=/var/folders/68/pcbyr3nj4yx033qz479rl3nh0000gp/T/Helicon
WebAutomaticSpellingCorrectionEnabled=true
com/apple/AppleModemSettingTool/LastCountryCode=US
com/apple/ColorSync/Devices=
com/apple/CommonPanels/CalibrateDisplay/identifier-28DA5305=com.apple.ColorSyncCalibrator
com/apple/CommonPanels/CalibrateDisplay/seed=-1120508567
com/apple/TimeZonePref/Last_Selected_City=
com/apple/mouse/scaling=3
com/apple/preferences/timezone/selected_city=
com/apple/scrollwheel/scaling=5
com/apple/sound/beep/feedback=0
com/apple/sound/beep/flash=0
com/apple/springing/delay=0.5
com/apple/springing/enabled=true
com/apple/swipescrolldirection=false
com/apple/trackpad/enableSecondaryClick=true
com/apple/trackpad/fiveFingerPinchSwipeGesture=2
com/apple/trackpad/fourFingerHorizSwipeGesture=2
com/apple/trackpad/fourFingerPinchSwipeGesture=2
com/apple/trackpad/fourFingerVertSwipeGesture=2
com/apple/trackpad/momentumScroll=true
com/apple/trackpad/pinchGesture=true
com/apple/trackpad/rotateGesture=true
com/apple/trackpad/scrollBehavior=2
com/apple/trackpad/threeFingerDragGesture=false
com/apple/trackpad/threeFingerHorizSwipeGesture=2
com/apple/trackpad/threeFingerTapGesture=0
com/apple/trackpad/threeFingerVertSwipeGesture=2
com/apple/trackpad/twoFingerDoubleTapGesture=1
com/apple/trackpad/twoFingerFromRightEdgeSwipeGesture=3
com/apple/trackpad/version=5
Post by Stas Yatsenko » 13.12.2016 12:52
Unfortunately, the log doesn't help. There has never been a complaint about project loading before so we didn't log anything related to it.
Could you give us any of the projects that exhibit such extremely long loading times? You can e-mail it to heliconsoft@gmail.com
DimitriKatsaros
Post by DimitriKatsaros » 20.12.2016 00:17
Sorry to respond with delay... busy on a project :-) I'll send them today. If you need the original tiffs, just let me know.
