Hi Guys,
I use Helicon pretty often for the photographer I work for.. I believe he has an older version, I wanna say 5.1? He said that someone once showed him which part of each image you have imported, have been used to create the final focused image but doesn't remember how it was done. I've tried it numerous times but cannot figure out how that works. The only thing I can think of of in the newer version is saving it as "SAVE DEPTH MAP" which shows the pieces of each image, but he made it sound as though he was able to see it happen as the images were being rendered. Plus I cant recall seeing the "save depth map" option on the older version that he has. Any ideas? Thanks!
Depth Map
Re: Depth Map
You should try Show map option which is available in Retouching mode. It will show where selected source image is used in result.
