Some slices rotated
MikeCT
Some slices rotated
Post by MikeCT » 23.09.2015 01:22
In a series of stacks, some of the individual slices are showing up rotated 90 degrees and these are rejected by Focus when stacking. This varies from about 10% to 30% of the total. Can I manually reset them so they are recognized?
Re: Some slices rotated
Post by Stas Yatsenko » 23.09.2015 15:15
You can fix it with some other image editing software, but not with Focus. The root cause of the problem is the erroneous output of your camera's orientation sensor. Disable the sensor in the camera body settings.
MikeCT
Post by MikeCT » 23.09.2015 21:46
Interesting. It is locked on a copy stand, so it is hard to imagine what is going on in the middle of a stack that would make it think it has rotated.
Post by Stas Yatsenko » 24.09.2015 11:32
Exactly why I call it a malfunction. This doesn't happen with new cameras in good working order.
salyangoz
Post by salyangoz » 26.09.2015 16:10
This happens to me quite often. I open the images in Photoshop, compare their rotations, if necessary, rotate them so that they will all have the same orientation & then save them as new files.
MikeCT
Post by MikeCT » 30.11.2015 19:08
As a follow up. As Stas suggested, turning off the Orientation Sensor worked. The reason it was happening is that when the camera is pointing straight down for copy stand work, the sensor gets disoriented.
