default file name
default file name
Most times that I save a file I get "Untitled" as a default file name.
Occasionally, say 1 time in 10, I get a name with first slice name, number of slices and parameter values. This is the format I have set up in preferences.
How can I make it work every time?
Re: default file name
What OS version and Helicon Focus version do you have?
Stas Thanks for reply
OSX 10.10.3
HF 6.3.5 Pro
OSX 10.10.3
HF 6.3.5 Pro
I have the same issue with default file naming, only on HF Pro 6.3.0, OSX 10.10.4. As an FYI, checking for updates with HF Pro (Help->Check for updates...) says that 6.3.0 is the latest version. Clearly not.
- Ken
- Ken
Ken
I suffered that check for updates bug for ages before I got on the website for another reason and found that there was a later version.
Rob
Rob
Thanks, we will check this again.
Stas
Any progress on this?
Is this problem unique to Ken and me, or does everyone get it?
My database is filling up with images named "Untitled".
Regards, Rob.
Regards, Rob.
Please change Helicon Focus menu Edit/Preferences.../General/Save filename template...
I did that 6 weeks ago and it did not work - hence my first post on this subject.
My choice of default file name is [SOURCE_FILE_NAME][COUNT][PARAMS].
Today
I have deleted that default name and re-saved it, and
deleted the app and reinstalled from dmg, and
deleted app and dmg, re-downloaded and re-installed the app, and
changed the default name to [DATE][TIME], to see if it performed differently.
I tested each of these cases and none of these actions had any effect - still "Untitled"
Focus version is 6.3.5 Pro
OSX version is 10.10.5
Since I did not have to register my newly downloaded version, I guess that there are some files that did not get caught in the delete. Maybe one is corrupted. Where should I look for them.
Rob
Today
Rob
We can't reproduce the problem so far.
Please download and install this updated Helicon Focus version: https://drive.google.com/file/d/0B_uKrE ... sp=sharing
Run it, go to Preferences -> Tools and press "Wipe settings". Then restart Focus and see if the error still persists.
Thank you Stas, that works.
Best regards, Rob.
Best regards, Rob.
