Hallo
My sourcefolders for HF are organised in Sub / subfolders
Folders: project name/lines of project/folders with pix to stack
Project
Project/L06
Project/L06/P087
Project/L06/P088
In HF you could choose add all subfolders to...
Will that be available in HF 6.2 as well? Otherwise I have to reprogram the outputfilenaming.
danibo
Sub sub folders enqeueu stacking in 6.2.2?
Re: Sub sub folders enqeueu stacking in 6.2.2?
Yes, you can add all subfolders, see File\Enqueue stack command.
The problem is that the resulting files will be named without project inforamtion, we have this request in our to-do list.
Stas
did I oversee something or missed a setting?
When I go to File/Enqueue stacks I can only choose Add multiple folders... when I choose in this mode folders which contain subfolders, nothing happens.
I can only select multiple folders which have pictures in it. Then HF 6.2.2 generates an enqueue from all selected folders.
danibo
danibo
Yes, this is correct, Helicon Remote does not look into subfolders. We decided that nobody need this
Stas
do you plan to add it?
If no I have to reprogram my workflow.
Let me know
danibo
Let me know
danibo
No, we do not plan to change this so far, sorry.
