I tried to proceed a focus job, but it works only up to 15 files.
Is it a problem to work further files?
One file is about 100mb.
Some times I take pictures are in macro size, so I have to take some more.
How can I save the problem. Is it possible to proceed for example 10 files and another 10 files and then do another from these to?
Thank you
Heiko
Not able to read files
Re: Not able to read files
Heiko,
What OS version and Helicon Focus version do you have?
Hello Stas,
my os version is 10.6.6 and helicon version is 4.2.7 32bit modus
Yes, this is possible.Heiko wrote:Is it possible to proceed for example 10 files and another 10 files and then do another from these to?
Normally 100mb image should not be a problem even for 32 bit version. Here are the links to older 4.1 and 4.0.5 version which had different memory management routines. You are welcome to try them. In the meantime we will try to fix this bug.
http://www.heliconsoft.com/downloads/He ... cus4.1.dmg
http://www.heliconsoft.com/downloads/He ... s4.0.5.dmg
