Nikon D3x Support?
Nikon D3x Support?
Are you going to support the D3x Raw Format directly?
Re: Nikon D3x Support?
Yes. We use three converters (embedded/nikon dlls, dcraw, adobe dng converter). All of them will add support for D3x soon if not yet added.
Do you know when you will add it with the embedded?
Adobe DNG converter and Dcraw both are supporting it already. Is it the same workflow for all converters? First converting the file, saving and then the converted file is processed by HF?
It would be great, if the embedded would do it directly without saving the converted files inbetween. I would imagine it should be faster then.
The saving of intermediary file is quite fast compared to conversion itself. Adobe DNG converter is an standalone program which we cannot integrate into our program.
