Hi, this may be a stupid question but here goes anyway
I have created my stack and wanted to turn it into a 3D video. The background of the image is however pretty untidy. I exported out the depth map (I assumed this is what 3D viewer uses), and airbrushed the background with 50% Black, assuming this would be neither up nor down.
Now how do I get the depth map back into Helicon? Am I missing something or can't I see for looking?
Any help would be much appreciated
Many Thanks
SimonL
Loading Depth Map?
Re: Loading Depth Map?
There is no way to import the depth map back. But you can use another trick. Go to the Retouching tab, select the first image and copy the backgroung from it. Internally the program will also update depth map the same way as you tried to do.
