Hello everyone,
i newly installed helicon focus and helicon 3d on my Mac and it looks that helicon focus is running fine.
Only if i want to export my rendering as a 3D-Model the following text appears: "Helicon 3D Betrachter zur Darstellung des Modelles bei Pfad nicht gefunden: /private/var/folders/lf/ny7srztj6f393t3kc2tbdcyr0000gn/T/AppTranslocation/E0FF3AF9-8196-44AE-8C64-1F4B67991816/d/HeliconFocus.app/Contents/MacOS/../../../Helicon3DViewer.app/Contents/MacOS/Helicon3DViewer" (Helicon 3D Viwer isn´t found under this path...)
What can i do? I installed both programs in the Program folder; helicon 3D is starting normal.
Thanks for every help.
Volker
Helicon 3d not found
Re: Helicon 3d not found
Are you using Helicon Focus 7.0.2 and the accompanying 3D Viewer?
Yes i do. I installed everything again and now it works fine. Thx a lot.
