USB-RS232
vansav8r
USB-RS232
Post by vansav8r » 24.12.2018 12:21
Hi, I am converting my home made stacking rail with a Trinamic controller and stepper motor I would be grateful if you could confirm if the following USB-RS232 cable cable off ebay would be compatible please?
https://www.ebay.co.uk/itm/FTDI-TTL-232R-5V-WE-CABLE-USB-RS232-SERIAL-CONVERTER/223252889110?hash=item33fae8be16:g:EfMAAOSwCcZaJ-Ku:rk:8:pf:0
Re: USB-RS232
Post by Stas Yatsenko » 26.12.2018 11:59
I don't know how we can confirm that without trying, it sorry. We don't have this specific cable, but it looks correct.
vansav8r
Re: USB-RS232
Post by vansav8r » 29.12.2018 18:19
Thank you I have ordered one.
Could you confirm one further thing please?
Am I right in assuming that when using a Trinamic stepper this will be connected to one USB port and the camera is connected to another USB port in order to handle the shutter operation?
Re: USB-RS232
Post by Stas Yatsenko » 02.01.2019 11:12
That is correct.
vansav8r
Re: USB-RS232
Post by vansav8r » 13.01.2019 18:17
Hi Stas,
One further question please, would Helicon Focus recognise just the USB / RS232 converter without it being connected to the Trinamic controller board, at present Remote is not recognising the connection of my converter / Trinamic / stepper.
Regards
Jim
Re: USB-RS232
Post by Stas Yatsenko » 14.01.2019 12:13
No, it won't detect just the converter. Or, rather, it will detect it internally but not show in the user interface if it can't communicate with the end device and establish that is indeed one of the supported devices.
vansav8r
Re: USB-RS232
Post by vansav8r » 14.01.2019 18:36
Ok it's possible then that the cheap Ebay £5 usb converter could be the problem, I will get the Farnell device and hope that solves the problem.
Thanks for the reply
Re: USB-RS232
Post by Stas Yatsenko » 15.01.2019 11:43
I don't know, serial converter chips are very cheap. We also used a cheap one from China for about $3 and it worked. I still think it could be a setup/configuration issue.
vansav8r
Re: USB-RS232
Post by vansav8r » 19.01.2019 18:36
Hi Stas,
Turned out to be the converter, I obtained the Farnell item and it worked first time.
Many thanks for your support which is appreciated.
