Batch Processing annoyances
Jim Fandango
Post by Jim Fandango » 14.12.2018 10:32
my standard process is always like taking tons of pictures during the day and processing images over night so the batch processing is of great help, but there are a couple of issues:
1) Stackdefinition when selecting thousands of pictures with lot of stacks:
1.1 why do I have to wait for exif info to be parsed just to answer a question which is obvious ? ( yes break up and proceed ) why not ask first - or add a checkbox "start automatically after splitting" ? ( this takes quite a while for 10000 pictures...)
1.2 no further information about stack content ( image numbers) is displayed to identify single stacks in the batch main window
1.3 stack content ( range of images processed ) is not stored in exif of generated tif ( nor elsewhere to support inputfiles <-> ouputfile correlation later on)
1.4 re-setup after out of discspace stop ( because of topic 2) is cumbersome (as 1.2, 1.3) you have to count available output images to delete splitted stacks ( after again 1.1) to be able to continue...
2) temporary files are only deleted on shutdown of application! (Not when a stack is finished!) I have 256 GB SSD dedicated to Helicon only which is not enough to process all stacks over night ( scenario is every day like 1.x)
3) Optionally it would be nice to have an option to also save the project files of a batch run automatically
what do you think ?
kr
Jim
Re: Batch Processing annoyances
Post by Stas Yatsenko » 14.12.2018 11:43
Hi Jim,
Those are all good suggestions, we will discuss and address them individually.
#2 has been addressed in Helicon Focus 7, are you using the latest version 7.0.2? It should no longer use all the available hard drive space and fail.
#3 is on our to-do list already.
Jim Fandango
Post by Jim Fandango » 17.12.2018 22:04
yes I am using 7.0.2
kr
Jim
Post by Stas Yatsenko » 18.12.2018 10:40
Then we need more details. How much free space is there on your Helicon Focus cache drive before you start processing? What kind of a stack does it take to deplete that space? Can you send us a stack that triggers this issue?
