Subject not aligned, help!
Mike984
Unread postby Mike984 » 24.09.2007 23:53
Is there a bug or something?
My subjects are not aligned right. What can i do to fix this?
Unread postby Dan Kozub » 25.09.2007 16:23
Protection system alarmed. Install anew and register the program again.
DanClarkWCP
alignment problem
Unread postby DanClarkWCP » 27.06.2008 04:43
Downloaded 3.79 for Mac last night, and decided to test it on what I thought would be a difficult subject. My first test turned out amazingly well, but I got horrible registration problems after that. Even if I aligned the files in Photoshop, then saved off each layer as a new TIFF, I still don't get very good results. However, if I load the stack of the first photo again, it still produces a great result. So, I'm assuming it's users error, but maybe not the same as the previous person experienced. I'm guessing that either I have too much camera movement between shots, or perhaps not enough contrast in the problem image stacks. I'm not sure what to do next.
Thanks in advance,
Dan
(221.51 KiB) Downloaded 1712 times
Unread postby Dan Kozub » 01.07.2008 17:29
Dan,
First of all, dark corners may be the reason. The program think they are part of the object and tries to align them.
Secondly, you can change limits of alignment in the Settings.
