Setting White balance under LED lighting
Anthony
Unread postby Anthony » 20.01.2015 23:52
Is there a means of setting the white balance in Helicon Filter using an index photo of a white-card? It is routine for me is to shoot stacks of images under a variety of LED sources, and I always shoot one reference white-card shot for every stack of images. I then run the RAW files through Olympus Master, including the white-card shot, and use the white-card to set the white balance for all the other shots in that stack. The drawback with using Olympus Master is that it converts the RAW to 8 bit tiff. I am interested in Helicon Filter's ability to work with 16bit tiff, and I would like to know if there is a convenient and similar way to have it adjust the white balance of the 16bit non-color-corrected output from Helicon Focus by using the white-card image I made for that image stack.
Re: Setting White balance under LED lighting
Unread postby Stas Yatsenko » 22.01.2015 12:38
Yes, you can open white sample card, go to Colors tab,correct colors using White Balance button or RGB sliders. Then save settings a a preset with a given name (e.g "Cold LED light").
Then you can apply this preset to all images shot in the same conditions and the WB will be adjusted accordingly.
Anthony
Unread postby Anthony » 22.01.2015 19:34
Stas, Thank you. I like your suggestion and will try that today. I had stumbled onto a different method, which is to use the "enque" function on a folder containing only the white reference photo and the Helicon Focus rendered photo.
