Transparency?
Ariel
Transparency?
Unread postby Ariel » 21.02.2007 07:23
Does/will Helicon Filter support transparency for:
*Viewing PNG files with transparency.
*Having soft shadowed frames which can be saved as transparency in the PNG format. (And speaking of soft frames, will Helicon ever be able to save soft frames with rounded edges, transparent/white [respectively] behind the rounded corners for saving in PNG/JPEG [respectively]?)
Unread postby Dan Kozub » 21.02.2007 10:18
I am thinking about adding full support of alpha channel in the next versions of Helicon Filter. This is not easy.
