Free vs. Home
Ariel
Free vs. Home
Unread postby Ariel » 20.02.2007 06:23
What can be done in Helicon Filter Home which can't be done in Helicon Filter Free? Is it that in Free, you can only save as .jpg, you can't use the expert preview mode, and that the retouching brushes disappear? Anything else?
Unread postby Dan Kozub » 20.02.2007 10:25
In simple mode (which is the only available in free version) you cannot use some filters (Chromatic abberation), equalizers, some brushes, advanced parameters on the tabs. But no limitation on image resolution or watermarks.
Ariel
Unread postby Ariel » 20.02.2007 21:09
So simple mode is the ONLY limitation? What about saving as non-jpeg files?
BTW: If you change modes in the retouching tab, the brushes don't change. You must go to a different tab and back before some brushes go away (or come back) in the simple mode.
Unread postby Dan Kozub » 21.02.2007 10:15
Yes, Free version also cannot save results in other formats than jpeg and bmp.
Ariel l
Unread postby Ariel l » 21.02.2007 22:13
Ariel
Unread postby Ariel » 25.02.2007 21:05
What about image stacking?
Unread postby Dan Kozub » 27.02.2007 09:55
Right, image stacking is not availabe for free users too...
