HF 4.5: filename suffix when save
Michael Johansson
Unread postby Michael Johansson » 16.02.2007 00:00
Everytime I save a new file in Helicon Filter 4.5 I get FILENAME_hf.TIF. In the previous version of Helicon Filter it was possible to exclude the Helicon Filters habit to include "_hf" in the file name when saving a new pic. In the 4.5 verion it seems to have dissapered. At least I can´t find were to disable this. Is it gone or am I blind?
If it´s gone please submit this possability in the next version. It is boring to manually excluede the _hf every time I save a new file :(
Unread postby Dan Kozub » 16.02.2007 09:45
I do not remember that we have such option in earlier versions but this is good suggestions for the next version, thanks
Michael Johansson
Unread postby Michael Johansson » 16.02.2007 10:06
Well, I can assure you there was such an option, somewhere in the preference tab if I remember correct. Very useful in deed.
Unread postby Dan Kozub » 16.02.2007 10:25
There is an option, but only for the batch operation in the queue dialog. Maybe you are right : )
Ariel
Unread postby Ariel » 16.02.2007 22:41
There is still this option! Go to menu Queue > Show queue... > at the bottom where it says "Output name:", you remove "_hf" > Click close. Then when you save a file, it won't include _hf in the name.
But this option should also show up in the main save dialog as an option for future saves.
Michael Johansson
Unread postby Michael Johansson » 16.02.2007 23:11
Thank you, ariel :D !
That worked. Perfect. Maybee that was what I did in the previous version also. Can´t remember.
Ariel
Unread postby Ariel » 23.02.2007 04:15
You're welcome!
Dan, can I make my display name here show up with a capital "A"? (Ariel vs. ariel)?
Unread postby Dan Kozub » 27.02.2007 09:44
I've fixed this. You do not have access to your profile in the forum?
Ariel
Unread postby Ariel » 27.02.2007 09:59
Thank you. I have profile access, but it doesn't let you edit the username.
