Helicon Filter 5 & DCRaw
colinbm
Unread postby colinbm » 23.12.2012 13:18
I use Sigma cameras & I want to open the raw X3F files with DCRaw, how is this done Please ? I have downloaded Helicon Filter 5.
I am useing my Sigma DP2 without the hot mirror for UltraViolet photography with an AstroDon UV filter. I have been told that DCRaw is best to open these X3F files.
I am a newby to post-processing :(
Cheers
Col
jpmccormac
Re: Helicon Filter 5 & DCRaw
Unread postby jpmccormac » 24.12.2012 00:55
If I understand your question correctly, you need to select the RAW converter in the Settings menu in HF 5. (latest verrsion is ver. 5.1.2 released on Dec. 17, 2012). Click Settings (or Ctrl-K) and select the RAW tab. Then click the Method drop down box and select DCRaw as your method of conversion. If this doesn't work, try the other methods until you find the one that works best for you. I don't shoot with Sigma cameras so I can't be more specific.
colinbm
Unread postby colinbm » 24.12.2012 01:17
Thanks very much JP....
Yes it is under 'Settings', Preferences, RAW, Method....scroll down to DCRaw :D
Lots to learn, but this gets me on this track.
Cheers
Col
colinbm
Unread postby colinbm » 24.12.2012 03:36
I am so impressed with the results I have purchased a licence for Helicon Filter :D
Cheers
Col
jpmccormac
Unread postby jpmccormac » 24.12.2012 03:46
Glad you like HF. It's one of the few software products that can currently handle my Canon G15 RAW images - other than Canon's DPP, which I don't care for. Check out some of the Help videos on YouTube at http://www.youtube.com/results?search_query=helicon+filter&oq=helicon+filter&gs_l=youtube.3..0.1331.4989.0.5731.16.10.1.5.5.0.101.872.9j1.10.0...0.0...1ac.1.wzpo1OVQvzA
colinbm
Unread postby colinbm » 24.12.2012 05:28
Thanks again JP.....
I have lots of tutorials to keep me busy over the holidays now :D
Sigma uses a Foveon sensor & its RAW processor is only geared to process visible light. It can handle InfraRed light reasonably OK, but with UltraViolet light its processing gets a bit cockoo. The DCRaw in Helicon Filter has handled the UV only light very capably.
Cheers
Col
