Task bar disappearing
Bosco
Unread postby Bosco » 15.02.2010 20:28
I'm sure this is an easy setting to find, but I can't find it.....sorry for the dumb question.
How can I stop the task bar for disappearing for the screen?
I'm using 5.0, and yes I'm a new user.
Bosco
Re: Task bar disappearing
Unread postby Stas Yatsenko » 16.02.2010 16:44
In the upper right corner of Helicon Filter you will find several small buttons. One of them is Full screen, the other one is Maximize/Restore window. If you use Full screen button, the program will open over the task bar.
Guest
Unread postby Guest » 16.02.2010 23:03
I have my task bar set to "autohide" When V5 is set for full screen, I can not "unhide" the task bar. This is not a problem with V4.93 or other programs.
Howard
Unread postby Stas Yatsenko » 17.02.2010 12:38
Howard, on my Window 7 any program in full screen mode (e.g. Firefox) also hides the taskbar if it is in autohide mode.
Guest
Unread postby Guest » 17.02.2010 14:16
Sorry Stas, I should have mentioned that I'm still in WinXP :) . I have the taskbar docked at the bottom of my screen. When I put my cursor at the bottom in V4.93 it pops up. In V5 it doesn't.
Unread postby Stas Yatsenko » 19.02.2010 15:49
Thanks for your report. We will fix this bug.
Guest
Unread postby Guest » 19.02.2010 21:33
Thanks!
