Workflow for NoiseFilter 1.39
pigasus
Unread postby pigasus » 11.04.2004 11:43
Dan,
Could you advise how to use the 2 settings in v1.39 (% and absolute value) to arrive at the best result?
Sally Schreiber
Unread postby Dan Kozub » 11.04.2004 12:37
Sally,
Click on the Noise Reduction control to make it active.
Start from the lowest value (10%) and increase level with arrow keys (up and down)
Notice the moment, when most of the noise disappears. That is your lower value.
Then increase Noise Reductiona and watch you details. Stop when they start to disappear. That is your upper level.
And choose something in between :)
pigasus
Unread postby pigasus » 11.04.2004 23:38
Thanks Dan. Any hints on how or when to use the absolute value?
Sally
Unread postby Dan Kozub » 12.04.2004 06:46
Sometimes noise level could be detected incorrectly. In this case you have to use absolute value to set noise reduction level.
rovision
Unread postby rovision » 07.06.2004 08:16
Dan, is it normal that colors and saturation is changed when applying any correction?
Please take a look at this page for a comparison between a straight out of the camera picture and one corrected with NoiseFilter:
http://www.fotomagazin.ro/test_foto
I applied the same correction to all 3 images on the right side, other data available in the page.
Unread postby Dan Kozub » 07.06.2004 08:47
thanks for reporting.
it is a strange problem, i will check it out and let you know.
dan.
Unread postby Dan Kozub » 10.06.2004 08:11
the current version we are internally working with does not have such problem.
Wait for the next release, please.
Dan
Hubbabub
Unread postby Hubbabub » 19.06.2004 13:10
Dan Kozub wrote:Wait for the next release, please.
Dan
Can you tell when is the new version going to get released ?
/Hubbabub
Hubba hubba zoot zoot................... :)
Guest
Unread postby Guest » 22.06.2004 11:08
the beginning of july
