How to crop with specific ratio
robbe
Unread postby robbe » 06.05.2008 11:40
I have purchased Helicom Filter and I'm very satisfied with the program and its numerous ease to use features.
One thing I'm missing is the possibility to crop images in a predefined ratio (e.g. 4:3 ; 16:9 ; ....). Is it possible to implement this in a future release, or is it possible to crop images this way already today.
robbe
Unread postby Dan Kozub » 08.05.2008 10:29
In the User Defined mode you can specify any aspect ratio.
robbe
Unread postby robbe » 08.05.2008 16:34
In the user defined mode I have to type the correct dimensions (inch,mm). If I want to have the ratio 16:9 I have to calculate the two dimensions by hand.
If there where a possibility to choose e.g. 16:9 and I can draw a crop-rectangle with this ratio over the image it would be much easier to crop to a specific ratio.
best regards
robbe
Unread postby Dan Kozub » 12.05.2008 17:26
here is what i mean
firexball
Unread postby firexball » 12.05.2008 23:04
By the way... it would be nice to have the "Portrait/Landscape" switch in the "user defined" mode. At the moment you have to manually change the aspect ratio, if you want to make a portrait picture out of a landscape foto...
Guest
Unread postby Guest » 25.05.2008 17:49
Thank you Dan,
that's it, what I was looking for.
The problem is that in the german interface the button "Change" is translated with "Farbwähler". It should be translated with "Ändern".
best rtegards
robbe
