Can Helicon Filter Open CHDK RAW Files?
genosmm
Unread postby genosmm » 04.03.2008 00:09
Recently installed CHDK on my Canon A570IS and have been very impressed with what CHDK can do. http://chdk.wikia.com/wiki/Main_Page
Can Helicon Filter open CHDK RAW files?
Did a forum search but found nothing
Gene
Unread postby Dan Kozub » 04.03.2008 11:01
Gene,
Please upload sample file to ftp://upload:nopassword@helicon.com.ua/httpdocs/
and we will try to add support for this raw format.
Guest
Unread postby Guest » 04.03.2008 19:48
Dan
Here is a link to CHDK http://chdk.wikia.com/wiki/Main_Page
I do not know if there are more than one type of CHDK RAW file. Was told that it was 10Bit but the latest DIGIC III processor allows 14-bit analog to digital image processing, as well as capture of 14-bit RAW files. http://www.imaging-resource.com/PRODS/XSI/XSIA.HTM
Gene
genosmm
Unread postby genosmm » 08.03.2008 19:35
Dan,
What is the Max file size I can upload?
Also what do you want the photos of?
Gene
Unread postby Dan Kozub » 13.03.2008 10:50
Gene,
There is no limitation on our ftp server. We need a sample file for tests.
Danylo
GrAnd
Unread postby GrAnd » 13.03.2008 19:44
Just FYI...
dcraw (and, therefore, programs based on it) supports CHDK RAW files for a number of cameras.
genosmm
Unread postby genosmm » 13.03.2008 20:14
Dan,
What Photos do you want? Target or Resolution Charts, Color Charts or just an Indoor or Outdoor photo?
Also do you want it taken at the lowest ISO?
As you can tell I do not have a clue as to what is the Best RAW photo to send.
Thanks for you patience!
Gene
Unread postby Dan Kozub » 20.03.2008 17:41
Several photos under different natural conditions would be fine.
genosmm
Unread postby genosmm » 27.04.2008 22:48
Dan,
Have not heard anything from you? Did you receive the photos and are you able to use them?
Gene
Unread postby Dan Kozub » 08.05.2008 10:13
Sorry, I've been very busy with ... a trip to Croatia :)
http://photo-os.com/dan/thumbnails.php?album=62&page=1
aquinas50
Helicon Filter and CHDK Files from Canon A570IS
Unread postby aquinas50 » 13.05.2008 19:15
If you run a free converter program which is linked to from CHDK that converts from the CRW format produced by CHDK to DNG, Helicon Focus can open the resulting file. dcraw 8.86 can process the CHDK files from the A570IS natively, without their being converted to DNG. Other RAW converters such as Silkypix or Rawtherapee can also read the DNG version of A570 files captured using CHDK.
Unread postby Dan Kozub » 20.05.2008 15:59
You can call DCRAW for you raw files direclty from Helicon Filter.
