About Helicon Filter
Helicon Filter is a program for enhancing digital images, it is intuitive but at the same time full of useful functions. Helicon Filter is designed for amateurs and for advanced photographers as well who want to obtain the high quality images without spending too much time. Helicon Filter provides all the most popular functionality, like:
helicon filter helicon filter helicon filter
Untitled Document
Workspace overview
workspace
A - main menu; B - buttons for switching between filters; C - taskbar; D - image display area; E - File information panel (on this screenshot it is inactive while the Presets panel is active); F - History panel (on this screenshot it is inactive); G - filetree; H - Thumbnails panel; I - Help panel; J - Expert mode panel (on this screenshot it is inactive); K - Presets panel.
Filters
tabs
Every filter provides a set of tools that perform similar tasks. For example, the Resize filter has tools for cropping and resizing, and the Brightness filter has tools to change brightness.
After you switch to one of the filters, you can use any of the tools available on the Presets and Expert mode panels.
The Presets panel gives quick access to the most common image processing tasks. You can use the default presets or you can create your own. Read more about presets here.
The Expert mode panel provides access to the full set of tools.
The Apply button applies the current filter and switches the program to default mode when no filter is selected.
The Cancel button switches the program to default mode when no filter is selected, without applying the current filter.
The Reset settings button resets the settings in the current filter to the default settings.
Folders and files panel
The Folders and files panel consists of the filetree, which shows the folder structure of your hard drive, and the Thumbnails panel, where you can see thumbnails of the images in a selected folder.
lock button/unlock button The pushpin icon allows you to lock or unlock a panel. If it's unlocked, it disappears as soon as you move the cursor away from it and appears when the cursor is near the left edge of the screen.
minimize button This icon allows you to minimize and restore the whole panel.
hide file tree button This icon lets you hide and restore the file tree.
The File information panel shows the image histogram, image information, and EXIF information. The histogram and metadata describe the original image and not the altered one.
On the image histogram, the horizontal axis represents the range of variation (from 0 to 255) in pixel brightness. This is the dynamic range of a digital image. The vertical axis represents the number of pixels at a brightness level, going from dark on the left side of the histogram to bright on the right side.
dark-image light-image balanced-image
Monochrome histograms
dark-image-histogram
light-image-histogram
balanced-image-histogram
Color histograms
histogram for dark image in color
histogram
histogram for balanced image in color
This image is dark: there is a peak on the left side and the rest is fairly flat This image is bright: there are peaks on the right side and the left side is flat This image is balanced: it has pixels across the entire dynamic range
Presets panel
The Presets panel gives quick access to presets. If no filter has been activated, there are presets for several filters available on the Presets panel. If you have switched to one of the filters, there are presets for one selected filter. Read more about the presets here.
Expert mode panel
The Expert mode panel contains all tools available for the currently selected filter. The panel can only be activated after you switch to one of the filters.
Thumbnails panel
The Thumbnails panel shows thumbnails of the images in a selected folder.
thumbnails panel
On the screenshot above the first three files are selected (note the green "v" mark v-mark); the other three - are not. The currently open file ("Candles.JPG") has the blue frame and red title.
You can call the popup menu by right-clicking on the Thumbnails panel. The operations offered by the popup menu are described below.
Note that opearations like Add to the queue, Rotate, Copy selected, apply to files selected with the green "v" mark v-mark. If the currently open file is not selected, the operation will not be applied to it.
The Select all command selects all the images in the folder. "Selecting" means selecting the checkbox below the image.
The Unselect all command clears the selection: none of images is selected.
The Invert selected command reverses the selections to the opposite state. (i.e., selected to deselected, deselected to selected).
The Add to the queue command adds images that have been selected to the queue waiting to have either a preset filter or currently selected set of filters applied. The "currently selected set of filters" means those filters that are applied to the image that is open at the moment. About the preset filters you can read here.
The Rename selected command  lets you rename one or more files using a template. For example, you can rename all your files, "2005.06.25 The Beach," so that your files are always shown sorted by date. More about renaming here.
The Copy selected command copies the files that have been selected into another folder.
The Move selected command moves the files that have been selected into another folder.
The Delete selected command moves the files that have been selected into the trash folder for deletion.
The Rotate commands rotate an image and save it with the original date and time, using a lossless operation in order to keep the JPEG quality from deteriorating. RAW files cannot be rotated with this function.
The Auto rotate command analyzes the EXIF orientation flag and rotates the image accordingly. The orientation flag is reset afterwards.
History panel
The History panel shows the list of filters you have applied to an image. You can enable, disable, edit, and delete any filter. To enable/ disable filters, select/ deselect the checkboxes in front of the names of the filters. To edit or delete filter, click on it to bring up the local menu for that filter.
Filters are listed in the same order as they were applied. You can enable/ disable filters in order to preview what an image would be like with or without a specific filter.
history panel
The Original image link lets you open the original image, and the Resulting image link opens it after any filters or changes have been applied.
 Untitled Document
Renaming files
The following dialogue will appear when you select one or more files, right-click on it, and then choose Rename in the popup menu.
Note: the shortcut for renaming a file is F2.
file renaming dialogue
In order to rename several files with the same name, you'll need to set up a template in the Template field. Or you can choose a template from the list of predefined templates. To see the list, expand the template combo box.
As you change something in the Template field, the example below it will also change at the same time, showing what the new file name will look like.
In order to embed image metadata into the template, choose the metadata you want to include from the list and then press the Add to template button.
Press Apply to start renaming the file or files.
 Resize Tab - Helicon Filter Help
Resizing and cropping
The Resize filter lets you rotate, crop a part, resize, and change proportions of images. The most common workflow is:
  • to rotate if necessary;
  • to set proportions (aspect ratio), for example, original or 3:2 or 1:1;
  • to draw the selection frame by clicking on the image and dragging the mouse (or by setting the coordinates of the selection);
  • to set resizing options, for example, one side should be 600px (the other one calculated according to the proportions), or other example: the image should be downsized to 10% of the original.
Rotation
Angle of rotation slider
If you need to rotate an image just a little bit, use the rotation slider.
Comment: To rotate by 90 or 180 degrees, go to the main menu and select Edit → Rotate image (+90) or (-90) or apply the shortcuts (R, L rotate for the current preview only; CTRL + R, CTRL + L rotate the image and save to disk). This can be done on any tab. You can also right click a thumbnail in the image browser to access the Rotate command.
image rotation sample image rotation sample
Original image Rotation +4,8 applied
Horizon button
It is just another way to rotate images. Click the button and draw a line on the image which is parallel to the horizon as it is on the image. The program will rotate the image so that this line becomes horizontal.
image rotation sample image rotation sample image rotation sample
Original image The horizontal line Rotation applied
Rotation with the help of the "green circle"
When you see the green crop frame on your image then in the corners of the frame you can notice the green circles image rotation . Set the cursor exactly on the circle, click and move the cursor in order to rotate the image.
Setting proportions of selection frame
Aspect Ratio
This feature helps to crop a part of an image with specified aspect ratio (proportions). The green frame is automatically set to the selected proportions. Drag the edges of the frame in order to change the area to be cropped. Set the cursor inside the selected area and wait for a second in order to preview the changes - the rest of the image will be darkened.
image cropping sample
Click on the arrow next to the icon and choose one of the predefined aspect ratios:
Free - means that you can change the proportions of the crop frame as you like.
Original - means that the frame will have the original proportions, you can only change size and change orientaion (portrait or landscape), see below.
Web - aspect ratios typical for images on the web. If you need another aspect use the User defined option.
Paper - aspect ratios which correspond most common paper sizes. If you need another aspect use the User defined option.
User defined - if you haven't found the needed aspect ratio among the predefined ones, you can define your own ratio. For example, you need a square image. Then you should set the aspect ratio to 1:1.
Setting coordinates of selection frame
Click on the arrow next to the icon and choose the Change option; the four new controls will appear and you will be able to set the coordianates of the selection. Alternatively you can draw the selection frame with the mouse.
Left size - sets the shift of the crop frame from the left side in pixels.
Top size - sets the shift of the crop frame from the top in pixels.
Width - defines the width of the crop frame in pixels.
Height - defines the height of the cop frame in pixels.
In order to hide the controls, click on the arrow next to the icon once again and choose Display only.
Changing orientation - portrait or landscape?
You can change the orientation of the selection frame, for example change 4:3 to 3:4. For this just click and draw the frame of the needed orientation on the image.
Max area
The Max area button sets the crop frame to the size of the original image. If you changed the crop frame, but then decided not to crop, then press this button to restore the frame to its maximum size.
Save and restore the current position and size of the crop frame
You can save the current crop frame's size and position save crop frame button. Then you can experiment with other sizes and positions, but you can restore the saved one by pressing the restore button restore crop frame button.
Resizing
Click on the arrow next to the icon and choose one of the predefined resize options.
Crop only - no resizing will be applied.
Dimensions - use this option if you know exactly one of the dimensions in units: pixels, inches, millimeters or cantimeters. If you set one of the dimensions and press ENTER or TAB, the other dimension will be calculated by the program using the aspect ratio of the current crop frame. If you use inches, millimeters or cantimeters you can also set the DPI of the resulting image.
Percents - allows setting in percents the size of the resulting image. Use this feature to downsize images.
Limit large side - allows setting the size of the bigger dimension in pixels. The other dimension will be calculated according to the current aspect ratio.
 Brightness Tab - Helicon Filter Help
Adjusting brightness
The Brightness filter allows correcting brightness, contrast, and removing haze. We recommend to use the automatic brightness correction first, and if not satisfied, try different controls and their combinations. The histogram can help to understand which controls work better for the current image, see Reading the histogram section.
Auto detect brightness
The Auto detect tool adjusts brightness fully automaticaly. The program will analyze your image and set other controls accordingly. You can choose the degree of adjustment: conservative, normal, agressive, or extreme. In most cases the conservative or normal adjustment will work very well. We advice to use this tool first. If you are not satisfied with the automatic brightness correction, you can always do it manually with the help of other tools.
Automatic correction is very useful for batch processing. You can add a folder with images to a queue and apply automatic correction. In most cases the brightness will be optimized automaticaly and you will have to correct only some images manually afterwards. Read more about batch processing here.
Contrast
The Contrast slider works well for very contrast or very monotone images. If you look at the histogram of the original image, you can see "a hill" in the middle because most pixels have average brightness. Increasing the contrast makes the image more diverse and interesting.
before increasing contrast after increasing contrast increasig contrast-histogram
Original image Contrast (+68) applied Notice how the histogram was stretched
towards the edges.
Brightness
The Brightness slider works well if you just need to make an image brighter. Increasing brightness makes dark areas brighter, but at the same time doesn't completely "overlight" the light ones.
On the sample image below the whole room became brighter, but the mountains in the window became almost undistinguishable. You can apply other controls to improve the situation with mountains. For example, try to darken the Highlights. Typically, you use the Brightness slider when you have most areas on your image dark.
brightness-before-sample brightness-after-sample brightness-histogram
Before applying Brightness After applying Brightness (+83) On the histogram you can see that the darks
were "stretched" and the highlights
were "compressed", but not lost
In some cases you can decrease brightness in order to make your image more dramatic. This will work well if you have a lot of light areas which are not overexposed.
Exposure
The Exposure slider makes all pixels brighter or darker by the same degree. The effect is similar to changing the ISO, exposure time or aperture on your camera. When moving the exposure slider please look at the histogram and control that pixels don't "disappear" beyond the limits of the dynamic range which can cause overexposed areas and loss of details.
exposure before exposure after exposure histogram
Original image The Exposure slider moved +1.3 You can see that the majority of pixels
moved right which means they became
brighter. The pixels are spread
more uniformly over the dynamic
range after the transformation.
Local contrast
The Local Contrast decreases contrast between large areas of shadows and highlights, but improves visibility of fine details within those areas.
It can be useful when there are only highlights (i.e. sky), shadows (i.e. trees) and almost no midtones. In this case you can see two big hills on the sides of the histogram. Applying local contrast will compress midtones and pull more details from the shadows and the highlights by stretching them.
local contrast before local contrast after local contrast histogram
Original image Local contrast slider moved +17 The pixels are spread more uniformly
over the dynamic range after the
transformation.
Shadows and Highlights
The Shadows and Highlights sliders allow changing brightness selectively for the shadows or for the highlights only, keeping the rest of the image unchanged.
The Shadows and Hightlights sliders are very useful with RAW files. JPEGs can become greyish if you apply strong trasformations, but not the RAW files. This happens because RAW files contain more information about color than JPEGs. So, the tip is to shoot in RAW if the images come out too dark. Compare the results for JPEG and RAW below.
If you apply the Shadows/Highlights try to change the Zone size - this can make the resulting image less greyish.
shadows before shadows raw after shadows jpeg after
Original image Shadows correction (+100) applied to RAW Shadows correction (+100) applied to JPEG
Zone size
The Zone size slider itself doesn't make any changes to the image, but it affects the work of other controls. It defines whether the transformations are based on the brightness of each individual pixel (zone size 0) or are based on some average brightness of several neighboring pixels. The slider defines the size of the zone to use for such averaging.
If you are not satisfied with the effect of applying other tools, try to change zone size. In order to understand which zone size is better for the a particular image, just change its value until you like the result.
Exposure warnings
Tick the Exposure warnings checkbox to see the overexposed and underexposed areas of the image. These areas will change in the process of transformations, so it is a good idea to control them periodically as you work with an image. The red areas are overexposed, the blue ones are underexposed.
eposure warnings original exposure warnings
Exposure warnings are off
Exposure warnings are on;
red - overexposed;
blue - underexposed
Auto contrast
The Auto contrast tool can optimize the contrast automatically. If you see that an image is grayish and dull then it's a good idea to use auto contrast. The program will analyze your image and will apply necessary transformations. You can choose the degree of contrast adjustment: conservative, normal, agressive, or extreme. The Manual option doesn't automate anything, on the contrary, it gives you the fullest control over the brightness adjustment and is explained below. We recomment trying different degrees of Auto contrast before adjusting the contrast manually.
From the histogram point of view it is a good idea to use the Auto contrast tool if you see that margins of the histogram are flat. The Auto contrast tool will "cut" the unused margins and "stretch" the histogram over the whole dynamic range. Red vertical lines on the histogram show the points where it will be cut.
before auto contrast after auto contrast
Original image Auto contrast (75%) applied The original histogram is cut by
the sides and the rest is stretched
over the full dynamic range.
Manual contrast adjustment
If you choose the"Manual option in the Auto contrast combo-box the two sliders will appear below: Black point and White point. They allow choosing the points where the histogram will be cut. The Black point slider defines the left limit and the White point slider defines the right limit.
Use the White point slider if you have a lot of unused space in the right part of the histogram. This will make grey toneless areas on your image brighter.
white point before white point after white point histogram
Original image White point slider moved to -55 The pixels are spread more uniformly
transformation.
And use the Black point slider if you have a lot of unused space in the left part of the histogram. In other words, if you would rather have some midtone-pixels black in order to make the image look brighter.
black point before black point after black point histogram
Original image Black point slider moved to +14 After the transformation some
grey pixels became black.
Haze compensation and gradient
For hazy and greyish images use the Haze compensation tool. Haze can be present from the very beginning or can appear after transformations, like increasing brightness of "shadows", for example.
If you want to apply the haze compensation partially, you can do this using the Gradient slider. You may wish this if some part becomes too saturated. If the Gradient value is 0, the compensation is applied to the whole image. If the value is negative (for example, -80) the compensation is applied to the 80% of the image bottom-up. If the value is positive, it is applied top-down.
There will be no visible border between the two parts because the transformation will be applied gradiently. The auxiliary tiny grey line marks the border for your convenience.
haze before haze after haze after 100
Original image
Haze correction +80
Gradient 70% top-down leaves the green
in the right bottom corner untouched.
Haze correction +80
Gradient 100% makes the green
too saturated.
Selection brush and Brightness brush
The selection brush selects some area of an image. After you have some selection you can return to the Brightness filter and apply any transformation either to the selection or to the rest of the image. Learn more about the selection brush and it's parameters here.
The brightness brush allows brightening only parts of an image, for example, a face. Alternatively, you can select the face with the help of the selection brush, return to the Brightness filter and increase Brightness or apply any other transformation. Learn more about brightness brush and it's parameters here.
Applying changes to selection
If your image has a selection made with the selection brush, you will see a new control at the bottom of the panel. Use it to define if you want to apply changes to selected areas, to not selected areas or to the whole image.
The histogram can help to understand which controls work better for the current image. When you switch to the Brightness filter, you can see the histogram at the bottom of the right panel in the Levels group.
The horizontal axis presents the range in which the brightness of pixels can vary (from 0 to 255). This is the dynamic range of a digital image. The vertical axis presents the number of pixels with the given brigtness. Dark pixels are on the left side of the histogram and the bright pixels are on the right side.
Dark image - there is a "hill" in the
left part and the rest is fairly flat
Bright image - there are "hills" in the
right part and the left part is flat
This image is quite balanced because
it has pixels belonging to the whole
dynamic range
After you apply transformations the histogram changes: it's upper part describes the original image, the lower part describes the result and the green curve with red dots describes the transformation which was applied.
image original image result
Original image Auto contrast: Normal (50%),
Brightness +16, Shadows +17
Histogram of the original image (above),
of the resulting image (below) and the
curve which describes the transformations
made to the image
 Colors Tab - Helicon Filter Help
Adjusting colors
The Colors filter lets you adjust the white balance, change the overall saturation or the saturation of selected colors, convert image to monochrome (black and white, sepia or else) and change brightness of the selected colors.
White balance
The sign of the wrong white balance is that colors look unnatural - either too cold or too warm.
too warm white balance normal white balance cold white balance
Too warm colors Correct white balance Too cold colors
The Color Temperature slider
The fastest way to correct the color temperature is to use the Color temperature slider. By moving the slider, you compensate the white balance mistake that was made when shooting the image. Move the slider to the right to make the colors look warmer and to the left to make them look colder. The color temperature is measured in Kelvins.
As you move the color temperature slider, you can see that the RGB sliders move simultaneously. This means that changing the color temperature is analogues to changing the intensity of RGB channels.
The drop-down menu can help to set the white balance automatically.
colors temp menu If your image looks yellowish like if it was taken under the tungsten light, select the Tungsten option here and the program will apply the automatic correction.
Typicaly, we get the wrong white balance, if the camera setting is wrong or the lightning conditions are complex. For example, you take a picture in a room with daylight, but the camera's white balance setting is "tungsten". Then the camera tries to compensate the tungsten light and makes the image colors colder than they should be. If the camera's white balance setting is "Auto", it is still possible that the camera makes a mistake which results in unnatural colors. This typically happens under complex lightning conditions, like in a dark room or outdoors at night or when there are several light sources at once.
You can correct the wrong white balance by making the color temperature higher or lower.
wrong wb corrected white balance
Original image - too cold colors
Color temperature: 9700K (6500K - default value )
too warm colors corrected wb decr temp
Original image - too warm colors
Color temperature: 4250K (6500K - default value )
The White Balance button
The White Balance button allows you to "tell" the program which area on the image is in reality white or grey. This enables the program to correct other colors accordingly.
Click on the White Balance button, the cursor turns into the eyedropper, then you click in the area which is white (or grey). The program will make the pointed area white (or grey) and will compensate other colors accordingly. This can help to correct the white balance. It is a very good method if you have a white or a grey object in scene.
too cold image wb corrected with eyedropper
Original image with Eyedropper tool The same image after correction
As you apply the white balance correction with the help of the eyedropper, you can notice that the RGB sliders move. This means that changing the white balance is analogues to changing the intensity of the RGB channels.
Memory Colors
The memory colors tool can be used to correct the white balance. The idea behind memory colors is that you create a collection of colors from objects that appear in a number of images, such as the skin color, for example. You add the correct color to the collection and then use it to adjust the white balance of other images in which everything, including the skin, looks too warm or too cold.
The memory colors workflow is described below.
STEP 1
Remember a color
m memory colors dialog
1. Choose a photo where you like the skin color.
2. Click the Memory Colors button and point to the skin color you want to remember.
3. When the Memory Colors dialog appears, click the Add this color button, enter the name (for example, "My skin, normal") and save the color.
STEP 2
Use the normal skin color to correct the white balance.
memory colors original apply memory colors result
Here the skin color is more orange than it should be; the other colors are also too warm.
1. Click the Memory Colors button and point to the skin color you would like to correct.
2. When the Memory Colors dialog appears, click at the color that you saved before ("My skin, normal") or click the Select button next to this color.
3. The program will correct the skin color and adjust other colors accordingly.
As a result, the colors are more natural in the whole image.
The memory colors can also be used to convert images to monochrome. When you convert an image, you can choose a single color: black, sepia, or any other color from the memory colors collection.
The Ignore brightness checkbox means that the selected memory color will be applied exactly as it was saved. If the checkbox isn't selected, the selected memory color will be applied after the brightness of the target image is taken into consideration.
The Color Map and RGB (Red Green Blue) sliders
color map
Color Map RGB sliders
The color map and RGB sliders give the full control over the white balance. Just drag the RGB sliders until the image has the desired hue. Or point the desired hue on the color map.
See also, RGB sliders, Saturation, and Spectral Sensitivity - What Is the Difference?!
Black & White
Tick this checkbox for making your image monochrome. By default the image will become "black & white". But you can choose any color from the collection of Memory Colors.
Click the Memory Colors button memory colors button and select the color.
original
black and white sepia blue
Original image Monochrome B&W image Monochrome sepia image Monochrome blue image
Show exposure warnings
Tick this checkbox to see the overexposed and underexposed areas of the image. These areas will change in the process of transformations which you make to the image, so it is a good idea to control them periodically. The red areas are overexposed, the blue ones are underexposed.
Saturation
The Saturation equalizer allows controling saturation of different colors individually and the Saturation slider changes the saturation of all colors at once. As you see from the example, the opposite for satuated color is grey.
The white vertical line on the equalizer (as you move the cursor over image) points to the color in the current cursor position. Move the cursor over the image and observer how the "white line" moves. Then click on the color which you would like to saturate and you will see the black vertical line which marks the color of the last click. This instrument helps you to find the exact color which you would like to saturate or desaturate.
original one color saturated
satuation all colors
one color saturated
Original image saturation histogram
  Saturation increased only for violet All colors saturated at once Saturation increased for violet, minimized for other colors; this allows making interesting selective-color-images
Right click the equalizer (or the slider) to reset the changes. See also, RGB sliders, Saturation, and Spectral Sensitivity - What Is the Difference?!
Spectral sensitivity allows changing brightness of one selected color. The sliders allow changing only red, green, or blue separately and the hisogram allows selecting more specific hue, fx. orange or violet.
The white vertical line on the equalizer (as you move the cursor over image) shows the color in the current cursor position. Move the cursor over the image and observer how the "white line" moves. Then click on the color for which you would like to change brightness; you will see the black vertical line which marks the color of the last click. This instrument helps you to find the exact color which you would like to make brighter or darker.
original blue brightness decreased original green saturated
Original image Original image
  Spectral sensitivity (brightness) of blue decreased, of red increased   Spectral sensitivity (brightness) of green increased
RGB sliders, Saturation, and Spectral Brightness - What Is the Difference?!
In brief, the RGB sliders change the hue, the Saturation changes color intensity, and the Spectral sensitivity changes brightness.
  RGB sliders Saturation Spectral sensitivity
original hue
saturation
brightness
Original image
The Red slider was moved to the right
Red hue, you can notice that white light between the leaves got the red hue
Saturation for red was increased with the help of the Saturation equalizer
Spectral sensitivity (brightness) of red was increased with the help of the "red slider"
Selection Brush
The Selection brush selects some area of an image. After you have some selection you can return to the Colors filter and apply any transformation either only to the selection or only to the rest of the image. Learn more about selection brush and it's parameters here.
Colors Brush
The Colors brush allows picking a color and painting with this color on the image. This is useful when retouching faces. Read more here.
Saturation Brush
saturation brush The Saturation brush allows changing saturation of a selected area on the image. This is also mainly used for retouching faces. Read more here.
Red-Eyes Brush
colors brushThe Red-Eyes brush allows fixing "red-eyes". Read more here.
 Noise Tab - Helicon Filter Help
Removing noise
When you switch to the Noise filter the program automatically detects the level of noise for your image and corrects it. In most cases this will be enough. But sometimes it is necessary to reduce noise more intensively for some parts. The Hightlights and Shadows sliders and the Equalizer allow reducing noise more intensively only for particular areas of the image - for highlights, for shadows, or for specific colors. These tools are described below.
noisy image noise removed
Noisy image Noise removed
The noise reduction is similar to blurring and it can result in loosing details. So, you need to find the reasonable balance between the details level and the noise level for your particular image.
You can change the parameters of the noise reduction algorithm in order to get better results for your particular image. This makes sense because different images have different noise and detail levels.
Hints and Tips
Noise reduction is an important step in enhancing images. All the other operations like sharpening and color balancing increase noise and make it more noticeable. It is important to clean the noise from the image at the very beginning. Even bright images shot on a sunny day contain a lot of noise so do not skip this step without a good reason.
  • Noise looks worse on a monitor screen than it does when printed.
  • Noise is noticeable on homogeneous areas (i.e. sky), and is hardly visible on textures (i.e. foliage).
  • Images with too much noise reduction look unnatural (plastic).
  • Do not spend too much time on a fine tuning - nobody will notice the marginal improvements.
Noise Level
The Noise level slider defines the level of noise reduction for the whole image. The default noise level is detected automatically after you switch to this tab. Noise level is measured in an abstract absolute value from 0 to 200. You can use this value to compare noise levels of different images.
Shadows
The Shadows slider defines the noise reduction level in shadows. If set to 0, it means that the noise reduction level in shadows is the same as in highlights and in midtones. If set to -100%, it means that there is no noise correction in shadows. If set to +100%, it means that the noise reduction level in shadows is twice more intensive (200%) than on the rest of the image.
Highlights
It works the same way as the Shadows slider, but for the highlights.
Noise Reduction Equalizer
The equalizer lets you define the noise reduction level for every hue in your image. Usually higher noise reduction levels are set for skin tones and the sky with lower levels set for green.
original with noise noise reduced everywhere denoised equalizer
Original noisy image Noise reduced on the whole image Noise reduced only for blue colors The Equalizer settings
Use the Noise Map to analyze the changes more precisely.
Algorithm parameters
Radius - higher values result not only in a cleaner image but also in artifacts on edges. Lower values preserve details but also show more noise.
Chroma - defines how much of chromatic noise should be removed. Chromatic noise shows up as points coloured in a complete different way they should be.
Noise reduction - defines how much of the luminance noise should be removed. In many cases an image looks more natural if chroma noise is completely removed, but a part of the luminance noise is left. Completely denoised image may look too "plastic".
Method allows selecting an algorithm which gives the best results on your particular image. For images with low noise, the "standard" method is good enough, for very noisy images try the"aggressive" method. These methods use completely different algorithms.
Noise Map
On the noise map you can see the noise reduction level for different areas of the image. The intensity of the red corresponds to the noise reduction level. You can use this map to check if fine textured areas are not considered to be noisy. It is also a good tool to see the effects of the noise reduction equalizer and the highlights/shadows sliders.
Selection Brush
selection brush The selection brush selects some area of an image. After you have some selection you can return to the Noise filter and apply any transformation either only to the selection or only to the rest of the image. Learn more about selection brush and it's parameters here.
Noise Reduction Brush
noise reduction brush The noise reduction brush allows reducing noise only for some parts of the image. For example, you can reduce noise only for faces. Learn more here.
 Sharpening Tab - Helicon Filter Help
Sharpening
The sharpening mechanism finds edges and makes them crisper and more noticeable by making the bright edges brighter (white halo) and the dark edges darker (black halo).
There are two sharpening tools in Helicon Filter: Sharpen fine details and Sharpen edges.
The Sharpen fine details tool makes images look less fuzzy by detecting and amplifying thin lines and fine details.
The Sharpen edges tool emphasizes all the edges by adding halos. If you use Sharpen edges, then the Sharpen fine details effect will be almost unnoticeable.
The Sharpen edges tool has several parameters that change the brightness and width of the halos.
original fine details sharpened edges sharpened
Original Sharpen fine details Sharpen edges
Hints and tips
  • Do not overdo sharpening, as the image will look too "digital."
  • To keep noise from being emphasized, set a higher value for the Threshold.
  • Do not set high values for Edge width without a good reason, as it produces too big halos.
Recommended Workflow
  • Set zoom to 100% or 50% to view image closer to its real size.
  • Play with the Sharpen edges slider to emphasize outlines of the objects.
  • If noise is emphasized, increase the value of the Threshold slider while simultaneously watching the Sharpening map.
  • Check if selecting the Suppress halos checkbox makes image look better.
  • Use Equalizer to adjust sharpening level for specific color ranges (i.e. skin, sky).
The Sharpen fine details tool detects thin lines and fine details and amplifies them. Wide and/ or smooth edges are not affected. Please note that such sharpening will be noticeable only on larger prints. If you plan to print a 5 megapixels image on 10x15cm (4x6") paper or downsize the image to 25%, fine sharpening will not be noticeable.
Sharpen Edges
The Sharpen edges tool adds contrast to the edges. Bigger values correspond to greater contrast.
The Edge width parameter defines the width of halos.
1 10
Edge width = 1 Edge width = 10
The Threshold parameter sets the minimal size of objects to be sharpened. If noise in your picture is increased, try setting a higher Threshold value.
The White halo parameter defines the intensity of white edge sharpening as a percentage to black edge sharpening. In most cases, white halos are more noticeable than black ones, which is why the default value is set to 50%.
Sharpening Equalizer
The Equalizer lets you define the sharpening level for every hue in the image. A common task is to keep skin details soft while sharpening the rest of the image.
Note: The Equalizer appears when the value of the Sharpen edges slider is not zero.
original
face sharpened
sharpened hue
equalizer
Original
Sharpen fine details 100,
Sharpen edges 50
Entire image sharpened
- notice the dots on the face
Sharpen edges 50
Skin color is not sharpened.
This is set with the Equalizer
Suppress Halos
The Suppress halos tool sharpens blurry edges without introducing white or black halos. If you already have a sharp image, the effect will be minimal.
original supress galos off supress galos on
Original Sharpened, Suppress halos is off Sharpened, Suppress halos is on
Sharpening Map
When you switch the Sharpening map on, you can see (in pink color) what parts are to be sharpened.
Sharpening Brush
The Sharpening brush can either sharpen or blur a part of an image. Read more about the Sharpening brush here.
Selection brush
The Selection brush selects a specific area of an image. After you have made your selection you can return to the Sharpening filter and apply any transformation either to the selection or to the rest of the image. Learn more about the Selection brush and its parameters here.
 Distortions Tab - Helicon Filter Help
Distortions
The Dstortions filter lets you correct radial and perspective distortions and vignetting, stretch your image horizontally and vertically, skew, rotate, and bend.
Lens correction
The Barrel/pincusion tool compensates radial (spherical) distortions by stretching the corners. These distortions typically appear on the wide-angle lens and when you take a shot from a short distance.
left original right
The Horizontal perspetive tool squeezes left or right side of an image. These distortions appear if you take a shot while being positioned closer to one side of an object.
left original right
The Vertical perspective tool squeezes the top or the bottom of the image. These distortions appear if you take a shot while being positioned closer to top or bottom of an object.
left original right
Geometry
The Stretch horizontally tool squeezes or stretches an image.
left original right
The Stretch vertically tool squeezes or stretches an image.
left original right
The Rotate tool can be useful if a shot was taken under wrong angle.
left original right
The Skew tool defines the shift of the upper part of an image.
left original right
The Bend tool  lets you straighten the horizon by lifting/sinking  image sides relatively to the its center.
left original right
Vignetting
Vignetting is an optical problem that results in unnaturally dark corners in the image. Vignetting is a common problem with many lenses and most often apears on wide-angle shots.
vignetting vignetting removed
The Level parameter definess the intensity of brightening the darkened edges.
The Curve steepess parameter defines how much of the image will be affected with un-vignetting.  High values result in correction only in the corners, low values result in brightening larger area.
Fill margins
Tick this checkbox off to have the margins filled with black color instead of the reflection of image sides. Margins appear after many operations: rotation, squeezing, skewing, etc.
margins off margins on
Fill margins off
Fill margins on
Grid
This checkbox switches on the grid. Use the grid to assess the distortions more clearly.
Selection brush
The Selection brush selects some area of an image. After you have some selection you can return to the Distortions filter and apply any transformation either only to the selection or only to the rest of the image. Learn more about selection brush and it's parameters here.
Distortions brush
The distortions brush allows distorting a part of an image, for example, to correct thin lips or a big belly or to corect the curve of nose or chin. Read more here.
 Untitled Document
Adding text
The Text filter lets you write something on your image, including a date. Several different effects will help you keep the text legible but unobtrusive.
To add more than one type or line of text, apply the current Text filter, and then switch to the Text filter once more to add another filter.
text sample text sample
Text
Type any text you want to have on your image into the Text template field. Use the Insert into text list below to add image metadata, such as date and time, file name, aperture, and/or shutter speed, etc., as well as the copyright and mu symbols.
Right-click on the text template field for the list of available actions: undo, cut, copy, paste, delete, select all.
The Clear text button clears all text.
The Date/ time format button shows/hides two combo boxes with the available formats for date and time.
Fonts and effects
Choose a font from the list and set the character set from the drop-down list below.
font sizeUse these buttons to change the size of the text or bring the cursor to the border of the text on the image, click, and drag it.
alignment buttonsUse the alignment buttons to align the text within the text borders.
The Effects combo box lets you choose one of four text effects:
no effect font No effect
shadowed text Shadowed
highlighted text Highlighted
embossed paper Embossed
color picking dialogue The color dialogue lets you choose any color for your text.
eyedropper You can also click on the eyedropper button, pick a color from your image and then click on it to set the text color.
The Transparency slider lets you make text partially transparent.
Text position
You can either position the text with the mouse or you can use the tools on the Position panel.
position buttonsUse these buttons to position the text on the image. The Margins control lets you indent the text from the image edge.
move text buttons Use the arrows to move the text. You can do the same using the following shortcuts: SHIFT + CTRL + Left (or Right or Up or Down) Key.
The Angle of rotation slider rotates the text. Or you can also use the mouse: highlight the cursor close to the small circle at one of the corners, then click and drag it.
 The Retouching tab - Helicon Filter Help
Retouching
The Retouching filter offers a complete set of brushes for retouching. Their most popular application of them is to remove various facial blemishes, such as pimples, wrinkles, scars, spots, etc. Below are some examples.
after
Original image
Brushes used: Delete Scratches, Clone, Change Color, Change Brightness, Blur/Sharpen, Distort
before after
Original image
Brushes used: Delete Scratches, Clone, Change Brightness, Blur/Sharpen, Distort
Common Parameters
Some brushes share common parameters.
The Intensity slider defines the strength of the brush effect.
The Brush size slider defines the diameter of the brush in pixels.
The Brush hardness slider defines the blurriness of the brush edge.
The Tolerance slider makes brushes "smart". In Helicon Filter all brushes are round, but with high tolerance you can apply the brush effect to an area that has a complex contour and similar color, like a face. The effect will be applied to the pixels that have more or less a similar color to those ones in the center of the brush circle.
The Smoothing slider defines the degree of automatic smoothing applied to the selection's edges and heterogeneous areas.
edge sensitivity
Tolerance 70%.
Notice, how the brush affects only sky
and leaves the trees and the building
untouched.
With the Fill contour button, you:
1) outline your chosen contour with a brush,
2) Click on the button
3) Click inside the contour and the brush effect is applied to the outlined area.
This works for all brushes except Delete Scratches and Distort.
Delete Scratches
The Delete scratches brush is optimized to fix small blemishes, such as wrinkles, scratches, pimples, etc.
This smart brush fills the area that it is applied to with the colors of neighboring pixels. The color(s) of the pixels in the area between the dashes and the outside of the brush circle is used to fill the area inside it.
The brush changes its orientation according to the movement of the mouse, because normally you will move the brush along a scratch. This works fine for areas with homogeneous texture.
If the scratch is near an edge, line or coarse texture, it is better to switch off the Auto orientation checkbox and use manual orientation. Deselect the Auto orientation checkbox and use ALT + Mouse wheel to change the orientation manually.
original delete scratches
Original image The brush is over the brown spot.
You can preview the result
Clone
The Clone brush can clone--i.e., copy--parts of an image.
The Intensity slider defines the opacity of the area to copy.
If the Move source area checkbox is unchecked, you select what you want to copy and then click on where you want to copy it, if the checkbox is selected, you do the reverse (first choose where to copy and afterwards choose what to copy). With this checkbox selected, you can copy complex objects piece by piece, as shown in the duck example below.
cloned ducks
Move source area: on
Texture only: off
Intensity: 100
First, click where you would like
to place the second duck and then
click over the original duck
until it is fully copied.
This poor duck was cloned
without any genetic engineering!
The Texture only checkbox allows you to copy the texture of the source image and preserve the brightness and the color of the target.
The Clone brush can be very useful for retouching faces. In some cases, it can remove skin blemishes better than the Delete scratches brush, for example, if the blemish is near an edge or on the gradient area.
original for cloning cloning step1
Original image Removing pimples
Intensity: 100
Texture only: off
cloning step 2 cloning result
Reducing wrinkles
Texture only: on
Intensity: 90
The wrinkles below the eyes
and the pimples were removed
Right-click or use the New area button to set the new source area.
Change Brightness
The Change brightness brush can either brighten or darken parts of an image. If the Intensity slider has a positive value, the brush increases the brightness, if the intensity is negative, the brightness decreases.
If the Remove haze checkbox is selected, this brush adds some saturation and brightens the grays. Please note that you can also apply haze compensation to the whole image on the Brightness filter.
original change brightness
Original image The foreground was brightened
Intensity +70, Tolerance 70%
original change brightness result
Original image
The skin was brightened
Intensity + 42 Tolerance 70%
Change Color
Use the Change color brush to change the color of parts of an image. For example, you can change the color of a T-shirt or fix the color of a face.
If you want to keep the texture of an area, select the Preserve the brightness checkbox. If it is deselected, the brush will paint over the original image with a solid color. You can also preserve the saturation of the original color by selecting the Preserve saturation checkbox.
You can choose the brush color in three ways:
1. Select the color from the current image by using the Change button.
2. Pick a color from the standard color palette.
3. Select one of the memory colors. You can also add to the memory colors.
original result
The Change color brush can be useful for retouching faces. For example, you can reduce the dark areas below the eyes by picking a brighter color from elsewhere on the face and painting it below the eyes with a low intensity.
change color under eyes change color eye result
Change Saturation
The Change saturation brush increases or decreases the saturation. If the Intensity is positive, the colors become more saturated. To make a selection monochromatic (black and white), set the intensity to -100%.
original saturated flower
Original image The colors of the flower are saturated
Blur/Sharpen
Positive values will sharpen the image and negative ones will blur it.
This brush is typically used to blur the texture of the skin and to sharpen the eyelashes and eyebrows. Use small values to blur the skin (-5, for example) because otherwise the skin will look too plastic.
The Radius slider defines how many neighboring pixels are used for the effect.
blur original blur result
Original image The background was blurred
sharpening original sharpening result
Original image The eyelashes, eyebrows, pupil and iris
were sharpened
Reduce Noise
The Reduce noise brush uses an aggressive algorithm to reduce noise in the selected areas only. By default, the Intensity slider is set to detect the noise level in the same way that it is done on the Noise filter. Higher values of the Intensity slider mean that more details will be treated as noise and removed.
Fix Red Eyes
This brush increases the saturation in the color of the pupils of the eye, and makes it darker as well. The brush is "smart" and tries to define the edges of the pupil if it is not round.
The Pupil darkening slider defines the brightness of the pupil. A value of 50 means that the brightness will be reduced by 50%.
red eyes red eyes removed
Original image Red eyes fixed with just two clicks
Distort
This brush can distort parts of images. You can fix such problems as face expression, thin lips, protruding ears, pot belly, etc.
The Both directions checkbox lets you stretch or squeeze an image area symmetrically in relation to the center of the brush. Use this option to make long objects thicker or thinner, such as lips or legs.
Distortion in one direction Squeezing in both directions Stretching in both directions
distort
distort
Original image Notice how the nose was shortened, and the lower lip
and chin lines were corrected
Use Ctrl+Mouse wheel or Up/Down keys to change the orientation of the brush. Hold down the Ctrl key to set the brush orientation.
Replace sky/background
This brush lets you clone the sky from an external image. The primary goal here is to replace an overexposed sky with a more appropriate one. Please remember that adding a completely different type of sky will make the image look unnatural due to the differences in lighting, direction of shadows, etc.
Please note that the Intensity slider changes the opacity of the entire sky. If you want to make only a part of the sky semi-transparent, you should use the Erase changes brush later on.
TIP: when painting near the horizon, set the Tolerance slider to the minimum value and paint with single clicks.
The Open sky library button opens a folder of pre-existing sky images that come with the program. You can also copy your own images into this folder.
The Open user's sky button opens a previously-used folder and loads the user's image of the sky.
The Horizon level slider lets you squeeze the image of the sky image so that the final image looks more natural.
replace background original replace background result
Erase Changes
The Erase changes brush is designed to erase the effect of the previous brushes selectively.  You can restore pixels to the state they were in before being retouched, or even to their original state.
The Erase up to combo box allows you to erase all changes going back to any previous step (for example, before they were retouched, before the brightness was changed, before conversion to B&W), including returning the image to its original state.
erase changes
First, the image was converted to B&W (with the Colors filter )
Next the effect was erased for the rose only with the Erase changes brush
Make Selection
You can achieve many effects with this brush. First, select an area, then switch to another filter (such as Brightness, Colors, etc.) and apply any available effect either to the selection or to the rest of the image.
As soon as you have made your selection and switched to a filter (Brightness, Colors, etc.), a combo box will appear at the bottom of the Expert mode panel, which allows you to apply changes either to the selection or to the rest of the image. The default is for changes to be applied to the whole image.
While all the other brushes are specialized and produce the most popular effects, the Make selection brush is universal: it allows you to apply any available effect to a part of an image. For example, the Brightness brush produces an effect analogous to moving the Brightness slider on the Brightness filter. However, there are many other tools for adjusting brightness that you can apply to a selection made with the Make selection brush.
You can apply a number of effects at the same time to either a selection or the rest of an image, as well as different effects to each part of an image.
You can save an image in which you've made a selection so that you can continue retouching it later, in which case you should save the file as a PNG.
selection original selection selection result
Original image Selection
Brightness increased for the
whole image and then again
for just the selection, followed by
increasing the saturation for
only the selection
 The Frame tab - Helicon Filter Help
Adding frames
To make your images look even nicer we offer five types of frames and some effects, let's take a look at them.
Artistic Frames
Those frames are probably most interesting. Helicon Filter is shipped with a few artistic frames, but you can download more free frames from our web site.
The Classic Frames Samples
classic frame classic frame
The Love Frames Samples
love frame love frame
The Grange Frames
grunge frame grunge
The Ornamental Frames
ornament frame ornament frame
The Postcard Frames
postcard frame
The Wooden Frames
wooden frame wooden frame
Original Image (Stretch) Frames
Stretched original as a background
+ "unfocused image (average)" effect
+ "shadow" effect
+ "monochrome" effect
+ "shadow" effect
Original Image (Mirror) Frames
Mirrored original as a background
+ "unfocused image (strong)" effect
+ brightness of background
Custom Background Frames
1 3
Gradient color frames
1 1
Frame type and size
TheFrame type is the most influential parameter, it defines what the frame will be like:
  • solid color frame
solid frame sample
  • gradient color frame
gradient frame sample
  • stretch image frame
stretch image frame
  • mirror image frame
mirrir image frame
  • custom background frame
background frame sample
  • artistic frame
artistic frame sample
The Frame width determines the width of the frame for all or for each of four sides of the image.
The Aspect control allows you to set the proprotions for the resulting image. For expample, you need the result to have 2:3 aspect ratio, even if the source image is square.
Frame effects
Depending on the frame type, this group of parameters contains controls to set various effects.
The Color controls let you define the colors for the solid color, gradient frames. They also define colors for the artistic frame if it is possible.
The Image control shows background or artistic frame that is used for the frame. The button on the right side of the image allows you to select different images from standard or last used folder.
The Brightness slider changes the brightness of the frame background.
The Additional effect control applies blurring or desaturation to the background image.
Image effects
These controls affect the transition between the image and the background.
The Effect type select allows you to add such effects as shadow, highlight or different types of transition between image and background.
The Effect width defines the size of the effect, i.e. width of shadow or transition area.
The Inner frame control allows you to add rectangle of specified type around the image.
The Rotation slider tilts the image inside of the frame.
 Aberration Tab - Helicon Filter Help
Chromatic Aberration (CA)
Chromatic aberration (CA) decreases the sharpness of images and removes color contours, lines, and spots that objects do not actually possess. It is caused by certain optical effects and processes in a camera sensor. Two types of CA occur most often in images taken with digital cameras: 1) purple fringing; 2) lateral CA.
Helicon Filter can help to fix both of these.
1) Purple/blue fringing (blooming):
fringing sample fringing sample
The diadem has a false purple contour. The purple contour has been removed.
2) Lateral CA
sample of lateral CA lateral ca removed
original lateeral ca sample lateral ca removed
Original image
Lateral CA usually appears
on the sides and in the corners.
The right top corner of the image
(see the red rectangle added to
the original image, left) has been
magnified to show the effect of
lateral CA on the white letters
The lateral CA has been removed.
The letters have no extra outlining.
Lateral CA is most often visible in contrasting areas on the sides and in the corners of images. It tends to make it look like the red and blue parts of the image have shifted from or to the center of the image.
For more about CA, you can read the following: http://www.dpreview.com/learn/?/key=chromatic+aberration.
Helicon Filter has two mechanisms for fixing CA.
1. To fix purple fringing, the program determines which areas have a brightness level higher than the brightness threshold.  Then it desaturates the pixels of the CA colors that are within a specified radius from the bright areas.
2. To fix lateral CA, the program distorts the red and blue color planes of the image to compensate for the error(s) created by the lens.
Recommended workflow
To fix purple fringing:
  • Use the eyedroppers (Current CA color & Other CA color) to mark the colors caused by CA.
  • Find the minimum radius that will remove the most obvious CA.
  • Starting with a low threshold, find the maximum threshold sufficient to remove all the CA.
  • Use the CA map to verify that the other parts of the image have not been affected.
To fix lateral CA:
  • Move the Lateral CA slider back and forth until you find the value that compensates for the CA.
  • If this doesn't help, then use the same approach as for fixing purple fringing.
Current CA Color & Other CA Color
The eyedroppers let you define two exact colors of CA by clicking on the image with the mouse pointer. Based on the desired Color tolerance level, the program will look for similar colors and desaturate them. Zoom in to pick the exact colors.
CA Parameters
The Radius slider defines the distance from the bright, overexposed areas that will be desaturated. Try to find the minimum radius sufficient to remove all the effects of CA.
The Brightness threshold slider defines the bright areas themselves. The program assumes that areas brighter than the threshold cause the blooming effect. Try to find the highest suitable threshold value to minimize the effects of CA in the other parts of the image.
The Color tolerance slider determines the degree of precision for the color match. A zero level of color tolerance means that only the exact colors defined by the current CA color and other CA color parameter will be removed (desaturated). A very high color tolerance (100) will include all colors in the processing.
CA Map
The CA Map switches the software to a special mode in which the intensity of the blue color corresponds to the degree of desaturation. In this mode you can check to see where your image is affected*.
Lateral CA
The Lateral CA slider changes the intensity of the changes in the blue and red color planes. Move the slider back and forth to find the value that will give the best result. Please note that this tool has no effect in the center of the image because lateral CA is most pronounced in the corners.
Lateral CA compensation should be applied before cropping.
*Editor's note: will be affected by the change(s) about to be made or has been affected by the CA? I think you might want to clarify this.
 Helicon Filter Help  - Preview window - Colors Tab
Artistic blur
The Artistic blur filter lets you add interesting blur effects to your images. You can create bokeh with different shapes, radiuses and intensity. Most of the time, you will not probably want to blur the whole image but rather a part of it. To do this, you must first select the portion of the image for the bokeh and then apply blur.
There are two ways to make a selection in Helicon Filter: 1) use the Selection brush and 2) use the Gradient selection filter.
Applying blur to a selection
1a. Switch to the Gradient selection filter, position the selection (Center X, Center Y sliders), set the correct size (Stretch X, Stretch Y sliders) and then set the gradient width along the sides of the selection. Invert the selection if necessary (Using the Invert effect checkbox).
1b. Or switch to the Retouching filter, pick the Selection brush and select the part of the image that you want (or do not want) to blur. It is possible to apply blur to either the selection or the rest of the image. So you should choose whichever part is easier to select.
2. Switch to the Artistic blur filter and then, in the combo box at the bottom of the Expert mode panel, choose either "apply to selected" or "apply to not selected." Try different bokeh shapes and radiuses; also try to boost highlights.
Bokeh shape
Try different shapes and choose whichever one you like best.
creamy circle bokeh Creamy circle bokeh
hard circle bokeh Hard circle bokeh
heart bokeh Heart shaped bokeh
hexagon bokeh Hexagon shaped bokeh
horizontal blur bokeh Horizontal blur bokeh
star bokeh Star shaped bokeh
Radius
The Radius slider allows you to make an image more or less blurred. If the radius is set to zero, there will be no blurring at all; the larger the value, the greater the blurring effect.
Boost highlights
The Boost highlights checkbox increases the brightness of bright areas and spots. It makes the bokeh brighter and more interesting.
 Untitled Document
Gradient selection
The Gradient selection tool lets you select a part of an image and then apply any other filter (Brightness, Colors, Sharpening, Artistic blur, etc.) to either the selection or the unselected part only. You can change the size, shape and position of the selection with several tools as described further below.
saint stephan island gradient selection sample gradient selection sample
Original image
Gradient selection with parameters:
Gradient profile: +50
Processing parameters for the unselected part:
Brightness filter: Brightness: -50
Colors filter: Saturation: -50
Center X
The Center X slider defines the position of the center of a selection along the horizontal axes. You can move it left and right.
Center Y
The Center Y slider defines the position of the center of selection along the vertical axes. You can move it up and down.
Rotation
The Rotation slider rotates the selection.
Stretch X
The Stretch X slider stretches or squeezes the selection horizontally.
Stretch Y
The Stretch Y slider stretches or squeezes the selection vertically.
Gradient profile
The Gradient profile slider defines the width of the gradient transition from the selected to the unselected area.
Show gradient only
The Show gradient only checkbox turns on the special preview mode in which the gradient selection is shown in black and the rest of the image is white. You can use this mode to see the exact contour of a selection if you cannot see it clearly in regular mode.
Invert effect
The Invert effect checkbox lets you invert a selection.
 Helicon Filter Help  - CA Tab
Saving
Helicon Filter offers two ways to save images: save with user defined parameters and quick save with default parameters which are implemented accordingly with Save As... and Save buttons.
Save As...
The Save as function lets you save an image after you've applied filters; the original image remains untouched. You can choose a target folder, enter a new file name and choose the file type.
For JPEGs and JPEG2000 file types ("lossy" formats) you can set the quality of the saved image. Please note that TIFF and BMP provide lossless storage of images. If you plan to process the image further, it is recommended that you store it in a lossless format (TIFF) or at least in 100% JPEG. If you plan to print the image, 10(82%) - JPEG quality will usually suffice.
The Calculate size button shows the size of the file for the selected file type and quality. If the file is too large, try lowering the JPEG quality. If this does not help, switch to the Resize filter and reduce the image to a lower resolution. If you plan to email the image, it is recommended that you keep the file size to 50-200KB and reduce it to 800-1280 pixels on the larger dimension.
The Open source folder option opens the folder that contains the original image.
The Save encrypted option lets you encrypt the image when you save it. The encrypted image cannot be opened in any viewer without a password that you set when you encrypt the image. In addition, in order to view an encrypted image you will need to open it in Helicon Filter and enter the correct password. If you want to decrypt the image, you will need to use another program from Helicon Soft - Helicon Photo Safe. You can open the encrypted image in Helicon Photo Safe and decrypt it. Read more about encryption, decryption, and safes in user guide for Helicon Photo Safe.
Save
The Save button on the taskbar works like a "quick save" because it saves the resulting image automatically without showing the dialogue for saving a file. The resulting image will be saved in the same folder and with the same name as the original one. The original image will be moved to a subfolder named "Originals" which will be created automatically in the folder where the original image resided before saving.
If you can't find the Quick save button on the taskbar, then expand the Save As... button which is on the taskbar after all buttons for switching between filters.
 Untitled Document
Printing
Helicon Print is a simple but smart utility for printing photos and a separate application that is still tightly integrated with Helicon Filter.
One of the advantages of Helicon Print is that you can add several images to a printing queue, set the same settings for all of them, start printing, and then forget about the printer until the entire queue is done.
How to print an image with Helicon Print
In brief, the printing workflow is: you add an image to the printing queue, then you set printing settings and then you launch printing.
To add the image to the printing queue, press CTRL+P (or expand the Save As... button on the taskbar and choose Print or go to the main menu and choose File → Print). On the Thumbnails panel you can select several files, right-click to call the popup menu and choose Print, all the selected files will be added to the printing queue.
IMPORTANT: The printing queue is cleared when you close Helicon Print. Therefore, don't close it each time after adding an image: just minimize the window.
You can also use Helicon Print as a separate application. Press the Windows START button → choose All programs → choose Helicon Software → choose Helicon Filter 5 → choose Helicon Print. Helicon Print will immediately show the Open File dialogue. There you can choose one or several images. If Helicon Print is already open, then press the Open new file button open new image.
It is also possible to paste an image from the clipboard using the paste button paste from clipboard or CTRL +V shortcut.
Once you have some images in the printing queue, there are five basic steps needed to prepare them for printing. Follow the steps on the screen print below.
helicon print
  1. Select the image that you want to print next. If you want to print all the images at once, just select one of the thumbnails.
  2.
  3. Set printer settings (optional step if the default settings are fine). Select your printer and set the paper size, source and orientation. Then set the properties specific to your printer. These typically include: print quality, photo paper type, color correction, etc.
  4.
  5. Configure size (optional step).
  6. A. Fit to page. The whole image will be printed, but some of paper may remain unused.
    B. Fill page. Some of the image may be lost, but the whole printable area of paper will be used.
    C. Original size.
    D. Custom size. Here you can set the desired proportions of the printed image in inches or centimeters. You only set one dimension here; the other will be calculated automatically according to the original proportions of the image. This option can be very useful if you want to print, for example, 4 10x15 cm. images on a single sheet of A4 paper. Switch to the custom size option, set the size to 10x15 centimeters and position the image in one of the four parts of the page. Print the image, then load the same piece of paper into the printer again with the same orientation, position the next image into the another corner and print that image. Continue for the rest of the images in this way.
    Use printable area. If this checkbox is selected, you will see the part of the page that will be printed upon. This varies for each printer.
4. Position the image on the paper (optional step). Click on the image and move it where you wish.
4a. You can also use the buttons to position and rotate the image on the page.
5. Press Print this page button. If you would like to print all the images in the printing queue with the same settings, press Apply to all. Then expand the Print button and choose Print all.
 Helicon Filter Help - Publishing
Publishing
Publishing to Picasa, Facebook, and Flickr
Quick publishing to Helicon Soft server (Publish to web)
Publishing to Picasa, Facebook or Flickr
You can publish batches of images to the popular web-galleries with the help of Helicon Web Gate utility. This is a FREE utility integrated into Helicon Filter and Helicon Photo Safe. Helicon Web Gates lets you upload images to the most popular photo sharing services: Picasa, Facebook, and Flickr.
Web Gate can be accessed from the Main Menu command, File → Upload via Web Gate, or by expanding the Save As... button on the taskbar and choosing Upload via Web Gate.
web gate dialogue
You can run Web Gate either from Helicon Filter (or Helicon Photo Safe), or as a separate application. There is a shortcut for it in the Windows Start menu. You can drag and drop files from any file manager to the Web Gate window (from Windows Explorer, from Total Commander, etc.).
Before uploading images you will need to have at least one Google account (for Picasa), Facebook account, or Yahoo ID (for Flickr). Of course, you can have multiple accounts for all those services as well.
To register a new account, use the following links:
Picasa Create new Google account
Facebook Sign up to Facebook
Flickr Sign up to Yahoo
The Workflow
This process is the same for Picasa, Facebook and Flickr. For example, if you upload images to Flickr, you can now choose the Google account in the combo-box above and click "Upload" again. The same list of images will be uploaded to Picasa.
While uploading, you can monitor the status.
Managing accounts
Before Web Gate can upload any files for you, it needs to "know" your credentials. In the toolbox you can see the Publish as combo box which lists the accounts that you've already used for uploads. If you haven't saved any accounts yet, it will have only one option: "Create new account."
accounts dilogue
Choose the "Create new account" option in the combo box or press the Manage accounts button in order to create a new account.
The Account Properties dialogue will appear. Enter a name for the account, using any text that will identify it for you, for example, "Tommy at Flickr." Then choose the photo sharing service, Picasa, Facebook, or Flickr.
For Picasa, you will have to enter the email and password that you use to sign in to Google.
For Facebook or Flickr you will see no more fields in the form, but when you click the OK button you will be redirected to a web page where you will enter your login ID and password. After you sign in to Flickr or Facebook, you will be prompted to authorize Helicon FIlter (or Helicon Photo Safe). After you authorize the software, you can close the browser and switch back to the Web Gate dialogue.
The Remember this account checkbox tells Web Gate to save the account. The next time it will sign in automatically. Uncheck this checkbox if you don't want the Web Gate to remember the account.
After you have signed in to an account once with the Remember this account checkbox selected, the account will appear in the combo box on the toolbox pane and Web Gate will sign you in automatically.
The Manage Accounts dialogue allows you to create, edit, and delete accounts.
Preferences
The Default file size option determines whether and how much the image(s) will be compressed before being uploaded. For example, if you choose 1600px, the image will be resized to 1600 pixels along the larger dimension, after which it will be uploaded.
The Stay on Top option controls the Web Gate window, determining whether or not remains on top or not. It can be handy to keep it visible if you drag and drop files to add them.
Publish to web
The Publish to web button on the taskbar allows you to publish and share images quickly. In just a few seconds, the resulting image will automatically be downsized and then uploaded to a server that belongs to Helicon Soft. You will receive a link, such as http://mob.heliconphotosoft.com/92130384.html, for ex., which you can copy and paste to share with your friends and colleagues.
Images published using the Publish to web command cannot be accessed by search engines and will, therefore, never appear in search engine results. Only those friends and colleagues that you give the exact link to will be able to view the image(s).
Images are stored on the server no less than a month and then deleted.
If you can't find the Publish to web button on the taskbar, then expand the Save As... button which is on the taskbar after all buttons for switching between filters.
 Untitled Document
Sending by e-mail
The Send by e-mail function automates the process of creating attachments. It also lets you downsize, convert, and encrypt an image before sending it.
If you can't find the Send by email button on the taskbar, then expand the Save As... button which is on the taskbar after all buttons for switching between filters.
send by email
The Calculate file size function lets you control the size of your resulting image in advance. This is particularly useful for email attachments, because mail servers often limit the size of messages or attachments..
 Helicon Filter Help  - Batch processing
Using queues for batch processing
Have you ever noticed how tedious it can be to apply the same corrections to several images in a row? Normally, you have to open an image, correct the brightness and color temperature, for example, and save the image. Then you have to open the next image, repeat the same operations, etc. And then the next image...and the next.
There is a better way to deal with this kind of repetition: with queues.
It's simple: just add several similar images to a queue and then let Helicon Filter do the work for you, applying the same corrections to all of them automatically.
Typical processing tasks for images in a queue
The following are examples of tasks that can be applied to images in a queue:
How to apply a current set of filters to images in a queue
Normally you'll set your filters (Brightness, Colors, Sharpening, etc.) for the first image in a series, add a number of similar images to a queue, and then let Helicon Filter apply the current set of filters to the queue. Here's what you do:
  1. Open an image. This image should be similar enough to the others you're going to add to the queue that they all will need the same corrections.
  2. Set the current filters. For example:
  3. Now you can either add several images from the current folder (see A) or add the whole folder to the queue (see B) or add just one image (see C):
    1. On the Thumbnails panel mark the images that you want to add to the queue. Right-click on the Thumbnails panel and select the option Add to the queue → Apply current set of filters.
    2. Go to the main menu and select Queue → Add current folder to queue → Apply current set of filters (or press CTRL + SHIFT + F7)
    3. Open the next image. Go to the main menu and select Queue → Add current image to queue → Apply current set of filters
  4. Open the queue (press F7 or go to the Main Menu and select Queue → Show queue) and confirm that the list of images and the filters are correct.
  5. Switch to the Saving results tab of the Queue dialogue and set saving parameters.
  6. Press the Start button.
How to use queues with presets
You can read about what the presets are and how to create them here.
If you have presets, you can apply them to images in a queue.
  1. You can either add several images from the current folder (see A) or add the whole folder to the queue (see B) or add just one image (see C):
    1. On the Thumbnails panel mark the images that you want to add to the queue. Right-click on the Thumbnails panel and select: Add to the queue → <Preset name>.
    2. Go to the Main Menu, select Queue → Add current folder to queue → <Preset name> or select Queue → Add current folder to queue → Load from library, and select the *.hfs file of the preset.
    3. Go to the Main Menu, select Queue → Add current image to queue → <Preset name> or select Queue → Add current image to queue → Load from library, and select the *.hfs file of the preset.
  2. Open the queue (press F7 or go to the Main Menu and select Queue → Show queue) and confirm that the list of images and filters are correct.
  3. Switch to the Saving results tab of the Queue dialogue and set saving parameters.
  4. Press the Start button.
Viewing queue and setting saving parameters
When you open a queue (F7 or Queue → Show Queue), the Queue dialogue appears.
Before making the following screen capture, I clicked on the image "Croatia, Krka.jpeg." Below you can see a thumbnail of it and the source folder, plus that the Brightness, Colors, Sharpening filters will be applied to it. To skip a filter, simply deselect it.
view queue dialogue
The Saving results tab lets you choose format of the results and output folder for the results. By default Helicon Filter will create a subfolder called "Filtered" in the source folder and will put the results there.
 Untitled Document
Presets
Presets are intended to give quick access to routine commands, such as increase brightness, sharpen, remove noise, or add saturation; presets can be applied to queues of images and this can save you a lot of time. Just add images to a queue, choose a preset, start the queue processing and then go take a rest while Helicon Filter processes your images. Read more about using presets with queues here.
The name of a preset tells what it does. Presets show up as buttons on the Presets panel and as options in the main (and popup) menu and as options of the Reset settings button.
When you first launch Helicon Filter, you'll see the pre-existing presets that we created and pre-loaded for you, but you can easily create your own presets and delete the default ones by going into expert mode. In order to switch to expert mode, activate the Expert mode panel.
presets panel
A preset is a file that contains the parameters for one or more filters. The filters in Helicon Filter are Brightness, Colors, Noise, Sharpening, Distortions, Text, Retouching, and Frame. A presets file is only intended to be processed by the software and not meant to be read by a person. Nonetheless, if it were readable, the contents of one would look like something like this: brightness: +20; contrast: - 2; sharpening: +20; put date and time in the bottom right corner.
Sometimes it's useful to save a preset in the same folder as the one with the images for which it was created. That way you can remember which filters you applied to your images, and you can still reuse this preset for other images. For example, if you processed several images and you want to remember the parameters for the future, save your parameters as a preset and then save the preset to the same folder as the images. This way it will be easier for you to find the preset later on. In order to save a preset in the same folder as the images, go to the main menu and select Settings → Save set of filters → Save to source folder.
Presets for several filters
A preset for several filters contains the parameters for several filters, such as, for ex., brightness, colors, resizing, and frame parameters, all in a single preset.
The presets for several filters appear as options in the main menu, as in the following:
The presets for several filters also appear in the popup menu when you right-click on the Thumbnails panel (with one or more images selected); then you can apply one of the presets to the selected images: Add to the queue → <Name of a preset>
On the Presets panel you can see the presets for several filters when no filter is activated at the moment; when any filter is activated then you see the presets for this active filter.
How to create a Preset for several filters
  1. Open an image
  2. Set filters. After switching to any filter, ativate the Expert mode panel and set the parameters. For example, you could choose to:
  3. In the main menu select Settings → Save set of filters → Save to library.
The presets for several filters should be saved into either the Presets library or the folder with the images for which the preset was created. The Presets library is a special folder: C:\Users\<username>\AppData\Local\Helicon\Filter\5\presets\Common\.
Presets for one filter
A preset for one filter contains the parameters for a single filter only, such as the parameters for brightness or colors, for example. When you switch to one of the filters then on the Presets panel you will see the presets for one filter; and when no filter is activated you can see the presets for several filters.
In expert mode, you also get quick access to the presets for a specific filter through the Reset settings button. If you click on the arrow to the right of the button, a drop-down menu with the presets for this filter will appear. This menu also allows you to save and load presets.
How to create a Preset for one filter
  1. Open an image
  2. Switch to any filter, for ex., to Colors.
  3. Switch to expert mode (activate the Expert mode panel)
  4. Apply corrections, such as converting the image to sepia, for example.
  5. Click on the arrow to the right of the Reset settings button and choose Save preset. Give the new preset a name that you'll remember the meaning of, and then save it. A preset for one filter should be saved into the special presets folder: C:\Users\<username>\AppData\Local\Helicon\Filter\5\presets\<filter_name>\.
 Helicon Filter Help  - Workflow
Shortcuts reference sheet
Using shortcuts is handy and efficient. You may want to print out the following page and keep it close at hand.
Basic shortcuts
Right mouse button Click on an image to compare it with the original or drag the image (pan)
Click on a slider or equalizer: to reset to default value
Space + Left mouse button Drag the image (pan)
Left mouse button
Show the magnifying glass (click on the image)
Mouse wheel Change the zoom factor (over an image), change the slider value (over a slider), or switch between 100% and "Fit to window" zoom modes (click on the image)
Retouching only
Mouse wheel For all brushes: change the brush size
Shift+Left button For only some brushes: draw a line between two points (previous and current ones).
Ctrl+Z. Undo
Ctrl+Y Redo
Right mouse button
Clones brush only: set a new source area
1,2,3,4,5,6+Mouse wheel For all brushes: change the value of a slider ('1' for Intensity, and so on. See "tooltips for the slider titles" for more details.)
Other commands
Ctrl-O Open a new file
Ctrl-S Save file in the original folder with a new name
Shift-Ctrl-S "Save as": to save a file in a recently used folder
Right arrow Open the next file in the current folder
Left arrow Open the previous file in the current folder
Ctrl-C Copy to clipboard
Ctrl-V Paste from clipboard
L, R Rotate the current image (counter-) clockwise for the current previewed image. The rotation will not be saved
Ctrl-L, Ctrl-R Rotate the current image (counter)-clockwise and save
Del Delete the image from the disk
Ctrl +, - Zoom in, Zoom out
Ctrl+Q Add the current image to the queue (with the current settings) and load the next image
F7 Show queue
Ctrl + Shift + F7 Add the current folder to the queue with the current set of filters
Enter/Esc Switch to/ from full screen mode
F1 Show help
 Preferences
Preferences
To open the Preferences dialogue, use the Settings → Preferences command from the main menu.
Image Viewing
Parameter name Description
Automatically rotate image when opening Tells the program to use EXIF information about the orientation of the image
Adjust brightness of the magnifying glass Determines whether or not the magnified area will be brightened. It lets you see details in the dark areas of the image more clearly.
Enable switching scale modes by clicking mouse wheel Allows you to switch between 100% and "Fit to window" modes with a single click of the mouse wheel over the image
Background color Determines the color under the transparent areas of the image
Resample method Sets the interpolation quality used for image resizing. Better quality means slower speed, as well as the reverse.
Accelerator for dragging the image Increases the efficiency of navigating through the main window by moving the image more quickly than a mouse pointer can travel
Set mouse pointer speed when retouching Adjusts the mouse sensitivity and precision for painting. When this is set at 50%, the mouse will move twice as slowly.
Panels
The following group of settings lets you customize the layout and behavior of the software panels.
Opacity of program panels Makes any unlocked panels partially transparent. The settings chosen here only affect the unlocked panels. Note: the lock/unlock icons are lock-icon/unlock-icon.
Time before unlocked panel closes Sets how many seconds the unlocked panel will stay visible after the cursor leaves it.
Sensitive area for hidden panels Defines the width of the area hidden near the edges of the screen. When you move the cursor over this area the hidden panels appear.
Layout of the browser Defines whether the thumbnails panel is positioned vertically or horizontally. If "Automatic" is chosen, the software will decide which layout is better depending on your screen dimensions, i.e., for wide screens it will be vertical, for ex.
Help hints appearance Defines where and whether the hints to current controls are shown.
Show captions for filter buttons Determine whether or not the captions to the filter buttons are shown. The filter buttons let you switch between filters (Resize, Brightness, Colors, etc.). If the captions are hidden, the buttons are minimized and the whole taskbar can be fitted into one row; with captions, the buttons are clearly visible and occupy a whole row on the taskbar.
Show navigation buttons of sliders
Determines whether or not small panels pop up below each slider; these panels make it easier to move a precise number of steps forward or backward or to restore the default or previous value of a slider.
navigation panel
Show all hidden dialogues Renews showing all prompts; this is especially useful for certain prompts, such as "Are you sure you want to delete this image?" where you may have selected the checkbox "Don't show this window again" in the past. With this button, you can begin showing all such prompts again.
Color management
In Helicon Filter, you can set different color profiles for saving, representing and printing images. This allows the software to save, represent and print the images accurately.
Use the following color profile when saving images Determines which color profile will be used when saving images. This list contains profiles that reside in the Windows system folder for color profiles.
Monitor profile Is used to represent images on the monitor. Your monitor has its own color profile, which is saved in the system folder during monitor installation. Helicon Filter will pull up the appropriate default monitor color profile, but you can set an alternate one if you wish.
Printer profile Allows you to make color corrections before printing images. If you've calibrated your printer and have your printer color profile, you can set it here.
RAW
The Method parameter determines the algorithm for developing RAW files. Helicon Filter contains three converters: embedded, DCRAW and AdobeDNG. It is also possible to convert a RAW file to DNG and then process the file with the embedded or DCRAW converters. Which convertor to use - depends on the RAW format. For different RAW formats (RAW files from different cameras) different convertors may work better.
You can select one of five options:
  1. Adobe RAW/DNG Converter can convert raw files to DNG (Adobe's raw format); this is a free Adobe utility that supports most popular raw formats; this is an external module which user can upgrade himself/herself.
  2. DCRAW can convert raw files to JPG; this is a thirdparty utility which supports a lot of raw formats; it is frequently updated; this is an external module which user can upgrade himself/herself.
  3. Embedded RAW Converter can convert raw files to JPG; this internal module was developed by Helicon Soft; it uses native SDK for most popular cameras (Canon, Nikon and others) and in some cases can give better results than universal converters.
  4. Adobe RAW/DNG Converter → DNG → DCRAW - this option should be used if your RAW format is not supported by DCRAW covertor. Your raw file is first converted to DNG with Adobe convertor and then to RAW with DCRAW.
  5. Adobe RAW/DNG Converter → DNG → Embedded RAW Converter - this option should be used if your RAW format is not supported bythe Embedded covertor. Your raw file is first converted to DNG with Adobe convertor and then to RAW with the Embedded converter.
Other
Action on filter changing Defines what happens when you go from one filter to other (e.g., from Brightness to Colors, for ex.). There are three options: apply changes, discard changes, or ask user what to do.
Format of quick saving Defines what the format of an image saved with quick save will be (SHIFT+CTRL+S or Save button on the taskbar or in the main menu File → Save).
Reset filter settings for new image Determines whether or not the filter parameters stay intact or are reset to default when the user loads the next image.
Automatically check for updates Determines whether or not the program should check the availability of newer versions.
Delete images into recycle bin Determines whether the images are deleted forever or first sent to the system recycle bin.
Allow only one copy of the running program Determines what happens if you want to run another copy of Helicon Filter.
Add shell extension Determine whether or not Helicon Filter is registered to process certain specific image file types or not.
Save settings of processed images Defines whether or not the software should restore the settings that were used earlier to process an image. This can be very useful if you are not satisfied with the result of a filter and want to change some parameters only while leaving the others as they were set during the first processing stage.
Temporary folder Sets up the temporary folder, where different user settings for the current session are saved.
 Helicon Filter Help - Installation
Installation
Run the installer and follow the instructions.
The installer will copy the files into the selected folder and save the settings into the system registry. Some additional libraries (i.e., Nikon, etc.) will be placed in the "C:\Program Files\" folder.
You can delete the program by either going to Control Panel or by running the installer again.
Registration
All features of Helicon Filter are available during the free 30-day evaluation period without any limitations. Once the trial period is over, the output image resolution is limited to 4 Mpixels without a license.
You can purchase a license from our web site (http://www.heliconsoft.com). The activation code will be sent to your email address automatically.
Upgrade
Helicon Filter connects to the server and checks for updates automatically after each launch. It shows a message if it finds an update. If you choose to upgrade later, it will ask the next day; if you say “later” again, it will ask in a week, if again you say “later” it will ask each month until a new update is available.
In order to upgrade manually go to the main menu and choose Help → Check for updates.
System requirements
To process 10 megapixel images, the recommended system configuration is:
The minimum system requirements are:
 Licensing
Licensing
Helicon Filter is a shareware program.  After thirty (30) days of evaluation period it switches to the free mode with limited functionality. More details at our home page (http://www.heliconsoft.com/heliconfilter.html).
Once you have purchased a license, all updates are free.
You can buy a license online here: http://www.heliconsoft.com/filter_purchase.html.
 Helicon Filter Help
Support
We support users via email (support@heliconsoft.com) and at http://www.heliconsoft.com/forum/.
Contacts
Web:
Email:
Phone:
Tel: +380-67-579-52-44
Copyright
Authors: Danylo Kozub, Vitaly Khmelik, Jury Shapoval, Vitaly Chentsov, Stanislav Yatsenko, Bogdan Litovchenko, and Vladimir Starikh
Helicon Soft Ltd. (c) 2000 - 2011
All rights reserved.
 Helicon Filter Help  - Plug-ins
Using Helicon Filter within Adobe Photoshop
After installation, the Helicon Filter plug-in will automatically be added to the most popular programs that support PS-compatible plug-ins.
Helicon Filter automatically registers itself in the following software programs:
If you have a program that supports PS-compatible plug-ins but is not included in this list, please write to us at support@heliconsoft.com. We will include it in the next version.
To register a plug-in manually for 32-bit versions, copy the following two files into the folder that has the plug-ins: "C:\Program Files\Helicon Software\Helicon Filter\library\HeliconFilter32.8bf" and "HeliconFilter32.ini." Register the 64-bit versions in the same way.
The Helicon Filter plug-in can handle 16-bit per channel images and images with an embedded color profile.
Using PS-compatible Plug-ins within Helicon Filter
Helicon Filter can be used to call PS-compatible plug-ins. You can see which plug-ins are installed in the main menu: Edit → Plug-ins.
Helicon Filter looks for installed plug-ins in the folders of popular software programs, such as Adobe Photoshop or Corel Photo-Paint*, and adds all compatible plug-ins to the Helicon Filter plug-ins menu.
To add external plug-ins manually, copy the plug-in file into the appropriate folder of Helicon Filter (C:\Program Files (x86)\Helicon Software\Helicon Filter 5\Plug-ins\).
If you are working with RAW or tiff images and an external plug-in does not support 16-bit-per- channel images, the program will convert the image to 8-bit and then back again to 16 bit after calling the plug-in. This may cause some loss of details. If it does, use this plug-in as the last step.
With the generous permission of Harald Heim, we have included Harry's Filters 3.0 in our installation. You can get the latest version of this software at www.ThePluginSite.com.
If you have problems using plug-ins within Helicon Filter, please write to us at support@heliconsoft.com.
